Add-In Guidelines
Add-in guidelines are intended to ensure consistency and integrity with the add-ins available in the File Exchange. Use best practices for scoping and namespaces. Review the “Advan...
Ryan_GilmoreAdd-in guidelines are intended to ensure consistency and integrity with the add-ins available in the File Exchange. Use best practices for scoping and namespaces. Review the “Advan...
Ryan_GilmoreHere is an add-in to allow people to generate and select OMARS experimental designs for 5, 6 or 7 factor experiments. The add-in was presented at the 2022 JMP Discovery Summit Europe, OMARS Designs A...
HadleyMyersNew for JMP 17 Pro: An Autotune option makes it even easier to automatically tune hyperparameters using a Fast Flexible Filling design. The XGBoost add-in for JMP Pro pro...
russ_wolfingerDescription The Word Import Tool add-in allows you to import text, tables, or images from a Word document. It can also create a table summarizing one or more Word documents. Laun...
Justin_ChiltonThis addin contains several utilities for working more efficiently with data tables. With it, you can: Quickly set the number of decimal places displayed in the data table. Set and cha...
brady_brady(18Aug2019) - A note from the author Hi, All! It's time to start thinking about a new version of the STK... I've got some things that I'd like to do, but I also want to hear from those using ...
MikeD_AndersonHow can JMP Technical Support help you? To make reaching out to Technical Support easier for you, we have created the Contact JMP Technical Support Add-In. This Add-In will open...
Justin_ChiltonThe Journal Text Sledgehammer is a tool for bulk formatting of TextEditBoxes within journals. To use: Open the Journal(s) you want to edit. If no journals are open, the p...
brady_bradyPurpose The Neural Network Tuning add-in is an alternative Neural Network platform that provides an easy way to generate numerous neural networks to i...
scott_allenこのアドインについてシステム要件事前の準備使い方How to use this add-in このアドインについて マテリアルズ・インフォマティクス(MI)、ケモ・インフォマティクスのためのアドインです。マテリアルズ・インフォマティクスは、材料の開発や探索をより効率的にするために、機械学習などの情報...
yuichi_katsumurPurpose The Capability Explorer add-in provides an interactive, six-graph summary for evaluating process capability. The report provides a process c...
scott_allenThis Add In creates a filterable data table so you can find rows that meet the conditions you specify.
julianPurposeKey FeaturesInstallationSystem RequirementsHow to Use ItExamplesFeedbackAcknowledgements and Copyright Notices Purpose The Torch Deep Learn...
russ_wolfingerThis add-in provides a Toolbar with several shortcut icons to quickly label and un/exclude data.
beta version: normalize column values with many possib...
Add-On for the Report toolbar. Additional shortcut icons to toggle control panel & legend on/off, automatically send the graph to Powerpoint and gener...
hogi
Purpose
The AddIn provides a GUI to automatically create normalized columns.
e.g.: weight normalized by weight of a typical 15year old boy/girl.
Ho...
Blog post:WebSocket This is a demo of using JSL->Python->WebSocket->Stackexchange to make a live GUI showing real-time updates at the stackexchange...
Craige_HalesThis addin allows the user to use a data filter to make simple or complex row selections, and then specify the column to write to and the value to wri...
txnelsonPurpose This add-in provides a needed bridge between the capabilities of the Nonlinear/Fit Curve platforms and Functional Data Explorer. It is design...
MikeD_AndersonHave you ever needed to share data and collaborate with a colleague who is not a JMP user? Perhaps you export data to Excel for those colleagues, onl...
Justin_ChiltonFill missing values based on existing values over groups on optionally non-sorted data.
jthiPurpose This add-in uses JMP mixed model platform to do stability / shelf-life analysis while considering random batches. Statistical details for the...
MikeD_AndersonA collection of visualization and analytical tools that leverage the capabilities of JMP for the semiconductor industry.
MikeD_AndersonEasy way to send JMP Tech Support question, problem or suggestion for enhancing future versions of JMP or JMP Pro.
Justin_ChiltonThe Preferences Manager Add-In allows you to save, export, import, and switch between preference profiles. A preference profile stores all customiz...
julianWhen working with the Measurement System Analysis platform, nested designs will create rows containing information on the 'nest' that each column is c...
Ben_BarrInghPurpose Using multiple versions of JMP at the same time can be confusing because all windows have the same icons. In addition, Windows often sends an ...
hogiThis add-in is meant to extend the number of statistics offered in the Summary platform, by including most of the additional statistics found in the D...
brady_bradyBrings snippets to JMP Script Editor (snippets are small re-usable code blocks).
jthiThe Imbalanced Classification add-in features sampling techniques that attempt to impose a more balanced distribution between the two classes. The sam...
michael_jmpThis add-in combines a number of visualizations related to consumer analytics, including Spider Plots, a multivariate plot on normalized values (r...
MikeD_AndersonAdd-in guidelines are intended to ensure consistency and integrity with the add-ins available in the File Exchange. Use best practices for scoping ...
Ryan_Gilmore
