JMPer Cable
Latest Posts
  • Using dates, times, datetimes and durations in JMP
    There are four common time-based values that you might have to deal with in JMP: dates, times, datetimes and durations.
    Jeff_Perkinson Jeff_Perkinson
    JMPer Cable |
    Oct 28, 2025 8:26 AM
    48353 views | 1 replies
  • New in JMP Clinical 19
    The latest release of JMP Clinical makes it the most sophisticated visualization and analysis tool for clinical trials the market. It has as much to do with our teams that build the software as it does its amazing functionality. Building on the powerful functionality of JMP Pro, JMP has delivered a solution that addresses the needs of a wide audience, including safety surveillance teams, medical m...
    geoffrey_mann geoffrey_mann
    JMPer Cable |
    Oct 14, 2025 7:34 AM
    2079 views | 1 replies
  • Understanding simple mediation analysis in JMP Pro
    When two variables are related, the natural next question is “why?” Mediation analysis helps answer that by testing whether a third variable, the mediator, explains how the predictor influences the outcome. It moves us from “X is related to Y” to “X affects Y by changing M.” For example, in education research, we might find that students who feel a strong sense of belonging are more interested in ...
    Hamid_Sanei Hamid_Sanei
    JMPer Cable |
    Oct 9, 2025 6:00 AM
    187 views | 0 replies
  • See the latest in the JMP Marketplace
    JMP Marketplace is an online platform to help you extend JMP as your needs evolve. Like other app stores, JMP Marketplace offers a curated selection of fully tested applications, add-ins, data connectors, and other extensions that enhance and expand JMP’s powerful capabilities.   Watch a demo of the Marketplace here.
    kristen-slappey kristen-slappey
    JMPer Cable |
    Sep 12, 2025 9:36 AM
    1856 views | 0 replies
    No supplied image
  • Choosing estimators in the Causal Treatment platform
    When treatment is binary, the Causal Treatment personality in JMP enables you to choose between four estimation techniques: inverse probability weighting with ratio adjustment (IPWR), regression adjustment (REGADJ), augmented inverse probability weighting (AIPW), and propensity score matching. You may be comfortable with one of these estimation methods, or you may have no idea where to begin. Alon...
    MeichenDong MeichenDong
    JMPer Cable |
    Sep 12, 2025 9:31 AM
    2028 views | 0 replies
    No supplied image
  • From correlation to causation: The Causal Treatment platform
    Randomized controlled trials (RCTs) and other carefully designed statistical experiments are the gold standard for answering questions about cause and effect. Randomly assigning experimental units (for example, participants in a clinical trial) to treatment and control groups balances the two groups so as to minimize the chance of substantive differences between them other than those caused by any...
    JMPer Cable |
    Sep 12, 2025 9:30 AM
    2129 views | 0 replies
  • JMP 19: What's new in data connectors
    Data access is fundamental to JMP. For the last several releases, we've been building infrastructure so that you can access data efficiently, regardless of where it lives. Once you to get the data you need into JMP, you can begin answering the questions you have. Every version of JMP adds new efficiency gains, performance improvements, and workflow additions. JMP 19 continues that trend.
    Prefer vi...
    willmorgan willmorgan
    JMPer Cable |
    Sep 12, 2025 9:20 AM
    2618 views | 0 replies
  • New in Graph Builder for JMP 19
    JMP 19 brings many improvements for Graph Builder. Here are a few of the most significant additions. Constrained smoothers The smoother element has a new method called P-Spline. It’s a cubic spline, just like the existing Spline method, but it’s parameterized in a way that better supports constraints. Monotonic trend curves are the most requested smoother feature, and now it’s possible – and then ...
    XanGregg XanGregg
    JMPer Cable |
    Sep 12, 2025 9:09 AM
    2790 views | 10 replies
  • What’s new in JMP DOE
    JMP’s latest release brings a fresh wave of updates to the Design of Experiments (DOE) platform, with new tools and smarter workflows that make it easier to design, simulate, and explore experiments. Whether you're screening factors, simulating responses, planning sample sizes, or trying to pinpoint the root cause of a failure, there’s something new to try out. Smarter fault localization with Baye...
    Ryan_Lekivetz Ryan_Lekivetz
    JMPer Cable |
    Sep 12, 2025 9:08 AM
    2144 views | 1 replies
  • Organizing and filtering data in the JMP 19 data table
    Data tables come in many sizes. Occasionally, I work with a table that is small enough to fit on screen: no scrolling necessary and everything I need, I can see. Most of the time, however, my data tables are tall, wide, complex, and multifaceted. For tables like these, the new data table organization and filtering tools in JMP shine. Let’s explore some real data to see why. I’ve been a longtime fa...
    julian julian
    JMPer Cable |
    Sep 12, 2025 9:06 AM
    1648 views | 2 replies
  • Going further with Python in JMP 19
    JMP’s latest release builds on the Python integration support that was introduced in JMP 18 by focusing on a fundamental part of the workflow: data access. By expanding data table operations and Python-JSL interoperability, accessing data becomes simple and convenient.   Prefer video? Watch it here.   Data Table operations The jmp.from_dataframe() function provides an efficient way to convert exte...
    Evan_Carr Evan_Carr
    JMPer Cable |
    Sep 12, 2025 9:01 AM
    2501 views | 2 replies
  • Control chart warning triage in JMP Live
    Overview If you have control chart warnings, you may want to: Get notifications about warnings that nobody has investigated yet.Assign warnings to another user, or to a user group, for investigation.Stay on top of the warnings that are assigned to you for investigation.Stay focused on the processes that still need attention.Know what happened, who dealt with it, and when by reviewing and downloadi...
    Aurora_TiffanyD Aurora_TiffanyD
    JMPer Cable |
    Sep 12, 2025 8:59 AM
    1989 views | 0 replies
  • Environmental monitoring with Process Screening
    Every pharmaceutical manufacturer needs to monitor its manufacturing facilities for possible contaminants from the environment. Mold from airborne spores and bacteria on surfaces are two of the threats that can ruin a batch. Other kinds of factories, like in the semiconductor industry, are threatened by airborne particulates. These facilities have specialized collection devices for environmental m...
    John_Sall John_Sall
    JMPer Cable |
    Sep 12, 2025 8:37 AM
    2219 views | 0 replies
  • Taking quality and process control to the next level with JMP Live
    JMP has long been a leader in providing the statistical tools needed by engineers and technicians to measure and analyze variations in the quality of products and the processes that produce them. These tools include: Control charts provide feedback on key variables and show when a process is in, or out of, statistical control. The Control Chart Builder platform provides an interactive, point-and-c...
    Eric_Hill Eric_Hill
    JMPer Cable |
    Sep 12, 2025 8:25 AM
    1807 views | 0 replies
  • Introducing the Bayesian Optimization platform in JMP Pro
    Bayesian Optimization, aka BayesOpt, is a new platform coming to JMP Pro 19. With it, you can use your existing data to fit a model and then use that model to intelligently decide where to sample next. These new observations are used to update the model and find even better samples. This process can start with a minimal number of runs, which means wasting fewer resources on suboptimal samples and ...
    Kasia_Dob Kasia_Dob
    JMPer Cable |
    Sep 12, 2025 8:20 AM
    2718 views | 0 replies
  • Visualizing co-occurrence using the JMP Network Plot add-in
    Yiran Song, who wrote this blog post, developed the Network Plot add-in as part of her JMP summer internship.
    Richard_Zink Richard_Zink
    JMPer Cable |
    Aug 27, 2025 9:00 AM
    839 views | 1 replies
  • Non-compartmental analysis of pharmacokinetic concentrations
    The forthcoming Pharmacokinetics (PK) report of JMP Clinical 19 summarizes PK concentration data including patient-specific concentration profiles and computes parameters from a non-compartmental analysis.
    JMPer Cable |
    Aug 19, 2025 7:45 AM
    1132 views | 0 replies
  • Getting started with Python integration in JMP® 18
    Get familiar with the Python integrated development environment (IDE) in JMP 18 and learn how to: Locate the Python IDE.Run a simple example.Install Python packages.Run JSL script from Python.Send a Python variable to JSL.Create a JMP data table from Python.
    yasmine_hajar yasmine_hajar
    JMPer Cable |
    Aug 14, 2025 6:08 AM
    30158 views | 18 replies
    No supplied image
  • Structural equation models with latent variable interactions: How to specify in JMP Pro
    SEM enables us to fit models that contain interactive effects among latent variables. However, these models require careful data preprocessing and can be tricky to specify. This tutorial lays out all the steps with an example in JMP Pro.
    Haley_Yaremych Haley_Yaremych
    JMPer Cable |
    Jul 29, 2025 6:00 AM
    1409 views | 0 replies
  • A Tour of the Structural Equation Models Platform in JMP Pro 18
    The SEM platform continues to mature after being introduced in JMP® Pro 15.
    LauraCS LauraCS
    JMPer Cable |
    Jul 29, 2025 5:45 AM
    2980 views | 0 replies
    No supplied image
