취소
다음에 대한 결과 표시
표시  만  | 다음에 대한 검색
다음을 의미합니까?
Browse apps to extend the software in the new JMP Marketplace
JMP Add-Ins
Download and share JMP add-ins
특집 항목
  • Modern Six-Sigma Add-In
    Modern Six Sigma Add-In is now available in JMP Marketplace! Please download it via Marketplace.   The Modern Six Sigma Add-In for JMP appears to be a tailored tool designed to streamline th...
    lkimhui
    JMP Add-Ins |
    Oct 17, 2024 10:36 AM
    5899 조회수 | 4 회신
  • Add-In Guidelines
    Add-in guidelines are intended to ensure consistency and integrity with the add-ins available in the File Exchange.    Use best practices for scoping and namespaces. Review the “Advan...
    Ryan_Gilmore
    JMP Add-Ins |
    Jul 23, 2024 10:59 PM
    6158 조회수 | 1 회신
  • OMARS Explorer
    Here is an add-in to allow people to generate and select OMARS experimental designs for 5, 6 or 7 factor experiments. The add-in was presented at the 2022 JMP Discovery Summit Europe, OMARS Designs A...
    HadleyMyers
    JMP Add-Ins |
    Mar 31, 2022 6:02 AM
    3112 조회수 | 0 회신
  • XGBoost Add-In for JMP Pro
    New for JMP 17 Pro:  An Autotune option makes it even easier to automatically tune hyperparameters using a Fast Flexible Filling design.     The XGBoost add-in for JMP Pro pro...
    russ_wolfinger
    JMP Add-Ins |
    Jan 6, 2025 12:27 PM
    51872 조회수 | 73 회신
  • Word Import Tool
      Description  The Word Import Tool add-in allows you to import text, tables, or images from a Word document. It can also create a table summarizing one or more Word documents. Laun...
    Justin_Chilton
    JMP Add-Ins |
    Jun 23, 2023 10:47 AM
    21095 조회수 | 9 회신
  • Data Table Tools Add-in
    This addin contains several utilities for working more efficiently with data tables. With it, you can:   Quickly set the number of decimal places displayed in the data table. Set and cha...
    brady_brady
    JMP Add-Ins |
    Feb 15, 2024 12:52 PM
    43136 조회수 | 32 회신
  • Semiconductor Toolkit
     AVAILABLE ON THE JMP MARKETPLACE: SEMICONDUCTOR TOOLKIT
    MikeD_Anderson
    JMP Add-Ins |
    Oct 10, 2025 5:06 PM
    141299 조회수 | 123 회신
  • Contact JMP Technical Support Add-in
    How can JMP Technical Support help you?   To make reaching out to Technical Support easier for you, we have created the Contact JMP Technical Support Add-In.  This Add-In will open...
    Justin_Chilton
    JMP Add-Ins |
    Aug 20, 2024 1:35 PM
    17250 조회수 | 7 회신
  • Journal Text Sledgehammer
    The Journal Text Sledgehammer is a tool for bulk formatting of TextEditBoxes within journals.   To use:   Open the Journal(s) you want to edit. If no journals are open, the p...
    brady_brady
    JMP Add-Ins |
    May 20, 2025 6:03 PM
    20429 조회수 | 18 회신
최근 게시글
  • Random Batch Shelf Life / Stability Analysis
    NOTE The capabilities provided by this add-in were enhanced and added to JMP Pro 19 in the Mixed Model personality of Fit Model.  Details can be found here: https://www.jmp.com/support/help/en/19.0/#page/jmp/stability-analysis.shtml%23 No further updates to this add-in are planned going forward and users are recommended to update to JMP Pro 19 to take advantage of the enhanced capabilities of the ...
    MikeD_Anderson MikeD_Anderson
    JMP Add-Ins |
    Oct 10, 2025 5:16 PM
    4580 조회수 | 13 회신
    A collection of visualization and analytical tools that leverage the capabilities of JMP for the semiconductor industry.
    JMP Add-Ins |
    Oct 10, 2025 5:12 PM
    141299 조회수 | 123 회신
  • Identify different JMP versions
    Purpose Using multiple versions of JMP at the same time can be confusing because all windows have the same icons. In addition, Windows often sends an open data file to the wrong JMP version for opening.   How to Use To make it easier to work with multiple JMP versions, install the add-ins and you will see in each JMP window which one is JMP 17, JMP18, JMP19:     System Configuration Add-in develo...
    hogi hogi
    JMP Add-Ins |
    Sep 16, 2025 6:39 AM
    1060 조회수 | 5 회신
  • Preferences Manager (with import/export)
      The Preferences Manager Add-In allows you to save, export, import, and switch between preference profiles. A preference profile stores all customizations you have made in the JMP Preferences (e.g. platform and report settings, graph settings, colors, styles, etc).    Basic Use: When you first install and launch the Preference Manager from the Add-Ins menu, you will not have any saved profiles. ...
    julian julian
    JMP Add-Ins |
    Aug 13, 2025 8:06 AM
    13817 조회수 | 15 회신
  • Launch Logger - track each time JMP is launched on a machine
    Launch Logger creates a small text file containing system details each time JMP is launched. These text files can be used to track how many times JMP is launched on a given machine.
    Jeff_Perkinson Jeff_Perkinson
    JMP Add-Ins |
    Jul 9, 2025 8:00 AM
    15651 조회수 | 9 회신
  • Plot Right Censored Values (Life Distribution)
    This add-in adds non-selectable markers (red triangles) at the times of right-censored values to an existing Life Distribution Report.   NOTES: The addin runs on the current data table and Life Distribution report.The addin only supports one by-group; if more than one “By” column is desired, concatenate the columns of interest and use the new column as the “By” column when running the Life Distrib...
    brady_brady brady_brady
    JMP Add-Ins |
    Jul 1, 2025 12:43 AM
    8229 조회수 | 1 회신
  • Student Add-In
    THIS ADD-IN IS NOW AVAILABLE ON THE JMP MARKETPLACE HERE. THIS VERSION WILL NO LONGER BE UPDATED.   Minimum version: JMP 16.1 This add-in adds a Student menu item to JMP that contains a variety of interactive applets for teaching core statistical concepts, such as sampling distributions and confidence intervals, as well as calculators for confidence intervals, hypothesis tests, and sample size cal...
    Ross_Metusalem Ross_Metusalem
    JMP Add-Ins |
    Jun 26, 2025 6:42 AM
    22769 조회수 | 5 회신
  • Femtet Add-in
    このアドインは日本語に対応したアドインです。他の言語での動作は想定していません。   ムラタソフトウェア株式会社が開発・販売するCAEソフト「Femtet®」とJMPを連携させるアドインです。
    ・Femtetアドイン情報
    バージョン:20241030
    動作対象のJMPバージョン:JMP 16 以降   ・Femtetアドインのインストールについて
    ダウンロードした .jmpaddin ファイルをJMPで開き、インストールの確認ダイアログが表示されたら、[インストール]ボタンを選択します。メニューには、[アドイン]メニューが追加され、[アドイン]メニュー内に、[Femtet]メニューが表示されます。   ・Femtetアドインのアンインストールについて
    メニューの[表示]→[アドイン]を選び、アドインステータスのダイアログが表示されたら、「登録済アドイン」リストにある[FemtetSim]を選択し、[...
    masakazu_okada masakazu_okada
    JMP Add-Ins |
    May 6, 2025 5:05 PM
    912 조회수 | 2 회신
  • Data Analysis Director
    This is designed to help new users become comfortable with running different analyses in JMP.  The add-in will ask the user to pick an analysis task, analysis goal, and data type.   After those selections are made the add-in tells you the statistical technique used for that analysis and where to find it inside of JMP.  It also provides some notes and assumptions about that test. The add-in has f...
    Peter_Hersh Peter_Hersh
    JMP Add-Ins |
    Apr 21, 2025 1:04 PM
    13000 조회수 | 15 회신
  • Torch Deep Learning Add-In for JMP Pro
    Purpose Key Features Installation System Requirements How to Use It Examples Video Tutorials Feedback Acknowledgements and Copyright Notices Purpose The Torch Deep Learning Add-In for JMP® Pro provides a no-code interface to the popular ...
    russ_wolfinger russ_wolfinger
    JMP Add-Ins |
    Apr 8, 2025 6:13 AM
    21685 조회수 | 26 회신
  • S-RPD Add-in
    このアドインは日本語に対応したアドインです。他の言語での動作は想定していません。   ・S-RPDアドイン情報 バージョン: 20250108 使用期限: 2026年1月31日 動作対象のJMPバージョン: JMP 16、JMP 17、JMP 18   ・参考書籍 製品開発のための実験計画法 | 近代科学社 製品開発のための統計解析入門 | 近代科学社   ・S-RPDアドインのインストールについて
    ダウンロードした  .jmpaddin  ファイルをJMPで開き、インストールの確認ダイアログが表示されたら、[インストール]ボタンを選択します。メニューには、[アドイン]メニューが追加され、[アドイン]メニュー内に、[S-RPD]メニューが表示されます。   ・S-RPDアドインのアンインストールについて
    メニューの[表示]→[アドイン]を選び、アドインステータスのダイアログが表示されたら、「登...
    JMP Add-Ins |
    Apr 3, 2025 3:00 PM
    833 조회수 | 0 회신
  • MCDA Add-in
    このアドインは日本語に対応したアドインです。他の言語での動作は想定していません。   ・MCDAアドイン情報
    バージョン:20250108
    使用期限:2026年1月31日
    動作対象のJMPバージョン:JMP 16、JMP 17、JMP 18   MCDAアドインは、JMPではじめる 統計的問題解決入門 |Ohmsha を購入された方に提供します。   ・MCDAアドインのインストールについて
    ダウンロードしたzipファイルを任意のフォルダに展開します。展開したフォルダにあるREADMEファイルの内容に沿ってご利用ください。   ・MCDAアドインのアンインストールについて
    メニューの[表示]→[アドイン]を選び、アドインステータスのダイアログが表示されたら、「登録済アドイン」リストにある[MCDA Add-In]を選択し、[登録解除]ボタンをクリックします。最後にダイアログを閉じます。   ご利用に...
    JMP Add-Ins |
    Apr 3, 2025 3:00 PM
    729 조회수 | 0 회신
  • Aveva/OSISoft PI Tools
    Connects to PI historian and pulls PI Point data directly into JMP.  Supports interpolated and summarized values, or retrieving all archived values.
    ih ih
    JMP Add-Ins |
    Mar 6, 2025 11:32 AM
    7867 조회수 | 7 회신
  • Normalization GUI
    Purpose The AddIn provides a GUI to automatically create normalized columns.
    For further details, please go to the JMP Marketplace.
    hogi hogi
    JMP Add-Ins |
    Jan 7, 2025 10:37 AM
    3910 조회수 | 6 회신
  • Graph Builder Toolbar
    Add-On for the Report toolbar. Additional shortcut icons to toggle control panel & legend on/off, automatically send the graph to Powerpoint and generate linecuts.
    hogi hogi
    JMP Add-Ins |
    Jan 7, 2025 10:27 AM
    6957 조회수 | 11 회신
    Modern Six Sigma Add-In is now available in JMP Marketplace! Please download it via Marketplace.   The Modern Six Sigma Add-In for JMP appears to be a tailored tool designed to streamline the Six Sigma DMAIC (Define, Measure, Analyze, Improve, Control) process within the JMP software environment. By offering a menu of shortcuts and integrating the relevant JMP tools, it simplifies the implementati...
    lkimhui lkimhui
    JMP Add-Ins |
    Dec 9, 2024 3:23 PM
    5899 조회수 | 4 회신
  • Moderation and Mediation Add-In
    Often as we are trying to gain insights from our data, understanding that two variables are related is not enough. We need to dig deeper and ask questions like: under what circumstances are they related? For whom are they related, why are they related, and how? The Moderation and Mediation Add-In enables easy specification, fitting, and visual probing of interactions in three popular models: moder...
    Haley_Yaremych Haley_Yaremych
    JMP Add-Ins |
    Dec 3, 2024 12:01 PM
    4479 조회수 | 0 회신
  • Forest Plot Add-In
    The Forest Plot add-in displays several confidence or credible intervals vertically. The user supplies the lower and upper limits, the center value (which could represent the mean effect) and labels for each interval from a data table. The user may provide a second center value to present additional summary values (e.g., medians) in the figure. Color options allow you to highlight intervals that ...
    Richard_Zink Richard_Zink
    JMP Add-Ins |
    Dec 3, 2024 7:40 AM
    38084 조회수 | 12 회신
  • JMP Notebook
    A Jupyter Notebook-style interactive presentation format in JMP.
    Justin_Chilton Justin_Chilton
    JMP Add-Ins |
    Nov 26, 2024 1:11 PM
    5641 조회수 | 3 회신
  • 日本語テキスト分析エクステンション
    このアドインは、日本語のテキストを分析するためのアドインです。このアドインは、他の言語では動作しません。   目的 [分析] > [テキストエクスプローラ]の日本語の前処理や可視化の機能を補完、拡張するためのアドインです。以下のようなことが可能です。 分析対象とする日本語の品詞を指定する名詞句のみを分析対象として指定する 共起ネットワークの描画 このアドインは、JMP 18のPythonインテグレーションの機能を利用しています。日本語の前処理は、spaCy、GiNZA , ja-ginzaを使用しています。共起ネットワーク描画のための前処理に、NetworkX を使用しています。   スクリーンショット         使い方 テキストデータが含まれる列は、尺度を「非構造化テキスト」に変更しておきます(該当の列を選択後、[列] > [列情報]から変更)。「アドイン」>「日本語テキスト分析...
    yuichi_katsumur yuichi_katsumur
    JMP Add-Ins |
    Nov 8, 2024 5:59 AM
    1371 조회수 | 0 회신
    Easy way to send JMP Tech Support question, problem or suggestion for enhancing future versions of JMP or JMP Pro.
    JMP Add-Ins |
    Nov 1, 2024 7:41 AM
    17250 조회수 | 7 회신
  • Estimating specific indirect effects in structural equation models
    This add-in allows users to estimate a specific indirect effect in the structural equation models (SEM) platform along with its bootstrapped standard error. After downloading and opening the file in JMP Pro, users will see a new option under the Add-Ins menu labeled "SEM Estimate Indirect Effect." Select this option and follow the instructions in the popup window.   The add-in is useful when the S...
    LauraCS LauraCS
    JMP Add-Ins |
    Oct 31, 2024 6:55 AM
    1301 조회수 | 0 회신
  • Spectris: Graphical spectral data processing
    UPDATES TO THIS ADD-IN WILL NOW BE AVAILABLE IN THE JMP MARKETPLACE You can find the new version of Spectris here: Spectris on the JMP Marketplace Purpose This add-in provides a needed bridge between the capabilities of the Nonlinear/Fit Curve platforms and Functional Data Explorer.  It is designed to handle common spectroscopic tasks like background subtraction, automatic peak searches, curve ref...
    JMP Add-Ins |
    Oct 24, 2024 6:49 AM
    6768 조회수 | 11 회신
  • Word Import Tool
    JMP Add-Ins |
    Oct 15, 2024 2:40 PM
    21095 조회수 | 9 회신
  • Venn Diagram
    This add-in constructs Venn diagrams with either constant or proportional areas.  The former accommodate up to five variables and the latter are limited only by the distribution of the counts corresponding to the variables.   The proportional-area diagrams call methods kindly provided by Lee Wilkinson and documented in his paper “Exact and Approximate Area-proportional Circular Venn and Euler Dia...
    JMP Add-Ins |
    107751 조회수 | 87 회신
