JMP Add-Ins
Download and share JMP add-ins
Featured Items
  • Add-In Guidelines
    Add-in guidelines are intended to ensure consistency and integrity with the add-ins available in the File Exchange.    Use best practices for scoping and namespaces. Review the “Advan...
    Ryan_Gilmore
    JMP Add-Ins |
    Mar 21, 2023 7:17 AM
    2963 views | 0 replies
  • OMARS Explorer
    Here is an add-in to allow people to generate and select OMARS experimental designs for 5, 6 or 7 factor experiments. The add-in was presented at the 2022 JMP Discovery Summit Europe, OMARS Designs A...
    HadleyMyers
    JMP Add-Ins |
    Mar 31, 2022 6:02 AM
    1271 views | 0 replies
  • XGBoost Add-In for JMP Pro
    New for JMP 17 Pro:  An Autotune option makes it even easier to automatically tune hyperparameters using a Fast Flexible Filling design.     The XGBoost add-in for JMP Pro pro...
    russ_wolfinger
    JMP Add-Ins |
    Feb 5, 2024 4:38 AM
    19745 views | 66 replies
  • Word Import Tool
      Description  The Word Import Tool add-in allows you to import text, tables, or images from a Word document. It can also create a table summarizing one or more Word documents. Laun...
    Justin_Chilton
    JMP Add-Ins |
    Jun 23, 2023 10:47 AM
    15870 views | 9 replies
  • Data Table Tools Add-in
    This addin contains several utilities for working more efficiently with data tables. With it, you can:   Quickly set the number of decimal places displayed in the data table. Set and cha...
    brady_brady
    JMP Add-Ins |
    Feb 15, 2024 12:52 PM
    26693 views | 32 replies
  • Semiconductor Toolkit
    (18Aug2019) - A note from the author Hi, All!  It's time to start thinking about a new version of the STK... I've got some things that I'd like to do, but I also want to hear from those using ...
    MikeD_Anderson
    JMP Add-Ins |
    Feb 26, 2024 8:28 AM
    94721 views | 102 replies
  • Contact JMP Technical Support Add-in
    How can JMP Technical Support help you?   To make reaching out to Technical Support easier for you, we have created the Contact JMP Technical Support Add-In.  This Add-In will open...
    Justin_Chilton
    JMP Add-Ins |
    Oct 22, 2021 6:54 AM
    13741 views | 6 replies
  • Journal Text Sledgehammer
    The Journal Text Sledgehammer is a tool for bulk formatting of TextEditBoxes within journals.   To use:   Open the Journal(s) you want to edit. If no journals are open, the p...
    brady_brady
    JMP Add-Ins |
    Dec 26, 2023 5:01 AM
    12960 views | 16 replies
Latest Posts
  • Bayesian optimization add-in
      このアドインについて このアドインは、JMPのガウス過程モデルを利用して、ベイズ最適化を行うためのアドインです。 システム要件 JMP 15以降 表示言語は、英語および日本語のみ   ベイズ最適化について ベイズ最適化は、逐次的な実験を繰り返し行い、最適解を探すときに使用される手法の一つです。ベイズ最適化の主な流れは、次の通りです。...
    yuichi_katsumur
    JMP Add-Ins |
    May 7, 2024 2:04 PM
    6062 views | 13 replies
  • Fill Missing Cells
    This tool allows user to fill missing values based on previous/next/nearest found value.There are already tools which can do this in a way or another (even JMP has fill rows), but the ones I have use...
    JMP Add-Ins |
    May 2, 2024 5:20 AM
    1718 views | 4 replies
  • Venn Diagram
    ...enn and Euler Diagrams”, available at http://www.cs.uic.edu/~wilkinson/Publications/venneuler.pdf  The corresponding computations are performed in Java, so you must have Java installed on your m...
    russ_wolfinger
    JMP Add-Ins |
    May 2, 2024 2:14 AM
    47051 views | 82 replies
  • Torch Deep Learning Add-In for JMP Pro
      Purpose   The Torch Deep Learning Add-In for JMP® Pro provides a no-code interface to the popular Torch  library for predictive modeling with deep neural networks.  T...
    SamGardner
    JMP Add-Ins |
    May 1, 2024 11:47 AM
    2093 views | 4 replies
  • Toolkit for Materials Informatics
    このアドインについて マテリアルズ・インフォマティクス(MI)、ケモ・インフォマティクスのためのアドインです。マテリアルズ・インフォマティクスは、材料の開発や探索をより効率的にするために、機械学習などの情報科学の技術を活用する取り組みです。 分子を機械学習で扱う際の課題は、分子をコンピュータが解釈できる数値にどう変換するか、という点です。その一つの解決策として「フィンガープリント」があり...
    yuichi_katsumur
    JMP Add-Ins |
    Apr 30, 2024 3:46 AM
    191 views | 1 replies
  • Capability Analysis JMP Add-In
    Purpose This add-in is designed to produce an attractive graphical rendition of a process capability study, and to make it easy to perform analyses across multiple columns of data.   How t...
    David_Burnham
    JMP Add-Ins |
    Apr 26, 2024 2:25 AM
    15327 views | 18 replies
  • JMP Acceptance Sampling Plan Add-In
    The acceptance sampling plan add-in provides a point-and-click interface for generating / creating, evaluating and comparing sampling plans. Specifically, one can create sampling plans by lot accep...
    stan_koprowski
    JMP Add-Ins |
    Apr 19, 2024 7:50 AM
    9492 views | 33 replies
  • Capability Explorer
    Purpose   The Capability Explorer add-in provides an interactive, six-graph summary for evaluating process capability. The report provides a process capability analysis and allows users to e...
    scott_allen
    JMP Add-Ins |
    Apr 18, 2024 2:04 PM
    2297 views | 5 replies
  • Spectris: Graphical spectral data processing
    Purpose This add-in provides a needed bridge between the capabilities of the Nonlinear/Fit Curve platforms and Functional Data Explorer.  It is designed to handle common spectroscopic tasks li...
    MikeD_Anderson
    JMP Add-Ins |
    Apr 17, 2024 9:10 AM
    2109 views | 8 replies
  • Unit Conversion Add-In
    This Add-In allows you to define and check the physical units of your columns and then convert them to different units. For example, define a column in milliliters/hectare and then convert it, a...
    EvanMcCorkle
    JMP Add-Ins |
    Apr 15, 2024 10:59 AM
    174 views | 0 replies
  • Tools for Battery Analysis
    This add-in contains tools for the analysis of data from Electrochemical Impedance Spectroscopy (EIS). It wraps functionality from the Python Package Impedance.py.   After installing the add...
    Jordan_Hiller
    JMP Add-Ins |
    Mar 27, 2024 1:02 PM
    277 views | 0 replies
  • German Documentation Add-In
    The Documentation add-in installs the individual PDF files for all JMP books, and the Documentation Library, which is a concatenation of all the books into one PDF. The add-in also installs a new men...
    Qiana_Eaglin
    JMP Add-Ins |
    Mar 14, 2024 3:01 PM
    154 views | 0 replies
  • Spanish Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    Mar 14, 2024 3:00 PM
  • French Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    161 views | 0 replies
  • Italian Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    137 views | 0 replies
  • JMP Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    Mar 13, 2024 1:17 PM
    652 views | 0 replies
  • Korean Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    Mar 13, 2024 1:16 PM
    273 views | 0 replies
  • Chinese Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    404 views | 0 replies
  • Japanese Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    Mar 13, 2024 1:15 PM
    421 views | 0 replies
  • English Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    Mar 13, 2024 1:14 PM
    688 views | 0 replies
  • Machine Learning with XGBoost
    Purpose Here is an attempt of my first application built with app-builder using the connection between JMP and Python to handle a complex machine learning algorithm. The purpose of this app is to...
    Franck_R
    JMP Add-Ins |
    Mar 13, 2024 12:03 AM
    6093 views | 14 replies
  • Rank Based Inverse Normal Transformation (INT) for Quantitative Trait Data
    This JMP Add-in is to transform non-normal quantitative trait data typically analyzed in Genome Wide Association Studies (GWAS). The method implemented is rank-based inverse normal transformatio...
    Chris_Kirchberg
    JMP Add-Ins |
    Mar 12, 2024 9:39 AM
    798 views | 3 replies
  • Apache Parquet file importer
    This add-in imports interactively Apache Parquet files (https://parquet.apache.org/) into JMP tables. It consists of two commands: Single file: select a single .parquet file, checks its validit...
    MassimoMartucci
    JMP Add-Ins |
    Mar 7, 2024 2:08 PM
    1879 views | 8 replies
  • Column Quick Swapper - easily change multiple Y and X-axis columns in Graph Builder
    Note: This was previously called Column Filter (jthi.column.filter). Uninstall that version before installing this.   This add-in lets you easily change multiple columns in your Graph Builde...
    JMP Add-Ins |
    Mar 6, 2024 3:57 PM
    514 views | 1 replies
  • Neural Network Tuning
    Updates November 27, 2023 - Version 1.1 - improvements and bug fixes, details are in a post below November 28, 2023 - Version 1.11 - minor bug fix December 15, 2023 - Version 1.2 - im...
    scott_allen
    JMP Add-Ins |
    Mar 5, 2024 9:09 AM
    3609 views | 18 replies
