  • Browse apps to extend the software in the new JMP Marketplace
  • This add-in is now available on the Marketplace. Please find updated versions on its app page
JMP Add-Ins
Unit Conversion Add-In
This Add-In allows you to define and check the physical units of your columns and then convert them to different units. For example, define a column in milliliters/hectare and then convert it, along with all its column properties, to floz/acre.
JMP already has an existing Units Column Property that documents these physical units and shows them in the Data Table and on graphs. This Add-In extends that to allow automatic extraction of units from imported data, easy management of many columns' units at once, verification of units, and unit conversion.
It adds a menu and toolbar with five tools and help. The Unit Conversion Add-In is currently available for JMP 18 only since it uses the new JMP 18 Python integration with the Pint Python package.
Converting from Fahrenheit to Celsius including Reference LinesConverting from Fahrenheit to Celsius including Reference LinesUnit Conversion with PreviewUnit Conversion with PreviewDetection of Units Property from Imported DataDetection of Units Property from Imported DataUnit ManagementUnit ManagementUnits DatabaseUnits Database
Comments
markschahl
Evan: Have been trying out the addin. One issue we've seen is that the original units must match known units exactly. Example: DEGF; DegF (degF) aren't recognized. Same with KLB/HR (klb/hr)
What is the best way to manage these 'recodes'?
