Blogs
Read about a broad range of data analysis topics and posts that inform your JMP use.
Latest Posts
  • Efficient subgroup visualization: JMP UpSet Plot Add-in for clinical trials and beyond!
    This blog was authored by Shuying Han. Shuying Han developed the UpSet Plot add-in as part of the Biostatistics Undergraduate Summer Internship (BUSI) program at the University of North Carolina at Chapel Hill.     Introduction
    Nowadays, statistical studies and clinical trials aim to uncover and communicate the stories within data, transforming raw numbers into meaningful insights. Data visualiza...
    Richard_Zink Richard_Zink
    JMPer Cable |
    Apr 24, 2025 9:00 AM
    31 views | 0 replies
  • Introducing the JMP Wish List Prioritization Survey!
    We are thrilled to invite you to take part in the pilot of the JMP Wish List Prioritization Survey, set to launch on July 3! Your feedback is invaluable as it will play a pivotal role in shaping the future of JMP by highlighting the ideas that hold the most significance to you.   Survey overview
    Within this survey, you will be provided with 100 "coins" to allocate to your preferred ideas. You have...
    LandraRobertson LandraRobertson
    JMP Blog |
    Apr 23, 2025 9:55 AM
    1476 views | 6 replies
    No supplied image
  • New version of the JMP Forest Plot Add-In
    Xueting Wang wrote this blog post. Xueting Wang developed this add-in as part of the Biostatistics Undergraduate Summer Internship (BUSI) program at the University of North Carolina at Chapel Hill.     Introduction What data visualization do you use when you want to view the evidence from different studies and interpret the overall findings of a systematic review? The forest plot is a good choice...
    JMPer Cable |
    Apr 22, 2025 12:31 PM
    106 views | 0 replies
  • Getting started with Python integration in JMP® 18
    Get familiar with the Python integrated development environment (IDE) in JMP 18 and learn how to: Locate the Python IDE.Run a simple example.Install Python packages.Run JSL script from Python.Send a Python variable to JSL.Create a JMP data table from Python.
    yasmine_hajar yasmine_hajar
    JMPer Cable |
    Apr 21, 2025 5:38 AM
    22385 views | 18 replies
    No supplied image
  • 15 Years and Counting: Explore the new JMP Discovery papers
    Learn about how JMP users from notable organizations explore data and overcome obstacles. See and read presentations from over 55 JMP Discovery Summits.
    gail_massari gail_massari
    JMP Blog |
    Apr 15, 2025 1:02 PM
    264 views | 0 replies
  • Lasso回帰の有効性をシミュレーションで確認 ~多重共線性のあるデータに対して~
    機械学習の分野では、変数が多いデータを扱うことが多く、そのようなデータを扱うと多重共線性が発生することがあります。その際、多重共線性を回避する手法であるLassoをはじめとする正則化回帰が用いられることがあります。   JMP Proでは「一般化回帰」という手法としてこの正則化回帰を利用でき、パラメータ推定値(回帰係数)を収縮や変数選択によって、多重共線性を影響を抑えた安定したモデル推定が可能になります。   以下の図は、Lassoによって回帰係数が収縮されたときの様子を示しています。レポート「元の説明変数に対する推定値」を見ると、効果の小さい説明変数は0(ゼロ)に収縮されており、Lassoが変数選択を行っていることが確認できます。 では、多重共線性が存在するデータについて、Lasso回帰はどのように有効なのでしょうか。本記事では、応答(Y)との真の関係をあらかじめ定めた仮想データを用い...
    Masukawa_Nao Masukawa_Nao
    Naohiro Masukawa |
    Apr 14, 2025 5:00 PM
    159 views | 0 replies
  • OneDrive and SharePoint Data Connectors Authentication
    This blog post is intended to help you understand and troubleshoot the OneDrive and SharePoint Data Connectors authentication process.
    willmorgan willmorgan
    JMPer Cable |
    Apr 11, 2025 4:59 AM
    172 views | 1 replies
  • Data integrity challenges and solutions: Expert insights from Chandramouli Ramnarayanan
    Data integrity is essential for accurate predictive modeling, regulatory compliance, and business efficiency. I spoke with Chandramouli Ramnarayanan, Global Technical Enablement Engineer at JMP, about the biggest data challenges companies face and the best strategies for improving data quality. From statistical monitoring to design of experiments (DOE) and anomaly detection, Chandra shares expert ...
    carla_paquet1 carla_paquet1
    JMP Blog |
    Apr 3, 2025 11:00 AM
    380 views | 0 replies
  • AI Riddle
    Please don't publish the explanation for this riddle.
    Craige_Hales Craige_Hales
    Uncharted |
    Apr 2, 2025 8:53 AM
    171 views | 0 replies
  • JMPのグラフビルダーで作る「サンキーダイアグラム」の描き方
    みなさんは、次のようなグラフをご覧になったことはありますでしょうか?近年、さまざまな分野で活用されているグラフです。   このグラフをはじめて見る方も、何となくその意味を感じ取ることができるのではないでしょうか。 このグラフは、「サンキーダイアググラム(Sanky Diagram)」と呼ばれています。   上記のグラフは色の好みを尋ねたアンケートの結果例です。「一番好きな色」、「性別」、「年齢」という設問を横軸に配置しており、各軸における間隔の太さは、回答数の割合に比例しています。   グラフからは「50代はBlueを好む割合が高い」、「40代の女性はPurpleを好む割合が高い」などの傾向が一目でわかります。   本記事では、まずサンキーダイアグラムの概要を説明し、その後、2つの分析例をもとに、JMPでサンキーダイアグラムを描く方法を紹介します。記事の最後には、操作方法を示したビデオも...
    Naohiro Masukawa |
    Mar 31, 2025 5:18 PM
    370 views | 0 replies
  • The art of what’s possible in semiconductor: Narrowing the variable list in design of experiments (DOE)
    Is it possible to optimize a plasma-enhanced chemical vapor deposition (PECVD) with just 25 test wafers? Absolutely! In semiconductor manufacturing, constraints such as a 25-wafer run on a tool are common, but they don’t have to limit success. Leveraging process data to inform experiment design is a winning strategy for getting effective results with limited resources.
    Jason_Wiggins Jason_Wiggins
    JMP Blog |
    Mar 31, 2025 4:57 PM
    718 views | 2 replies
  • Procter & Gamble veteran describes an analytics journey that saved millions
    Procter & Gamble veteran Cy Wegman on the importance of a data-driven culture, key leadership attributes, and more.
    anne_milley anne_milley
    JMP Blog |
    Mar 28, 2025 12:21 PM
    3281 views | 3 replies
  • RUTF食品研發案例:使用混料設計實驗精準改善配方
    對食品研發來說,每一次實驗都可能浪費原料與時間。透過有系統的實驗設計與數據分析,這家公司做到了「用最少的試驗,得到最多的資訊」。
    JMP_Taiwan JMP_Taiwan
    JMP Blog |
    Mar 26, 2025 3:59 PM
    258 views | 1 replies
  • JMP is Pythonic! Enhanced Python Integration in JMP 18
    JMP 18 has a new way to integrate with Python. The JMP 18 installation comes with an independent Python environment designed to be used with JMP. In addition, JMP now has a native Python editor and Python packages specific to JMP. This JMP Python environment has enhanced connectivity and interaction with JMP, which means using Python with JMP has never been easier. In this series of blog posts, I ...
    SamGardner SamGardner
    JMPer Cable |
    Mar 26, 2025 10:32 AM
    9601 views | 11 replies
  • 手機螢幕耐久性研究:跌落測試與統計分析揭示耐用性差異
    手機螢幕的耐用性對消費者和製造商至關重要。本研究透過跌落測試與統計分析,評估兩種鋁矽酸鹽玻璃螢幕的耐久性,探討是否達到97%成功率標準,並比較其性能差異。
    JMP Blog |
    Mar 26, 2025 6:48 AM
    323 views | 0 replies
  • New in JMP® 18: Python jmp.DataTable and pandas.DataFrame
    JMP 18 introduces a lot of new capabilities, including revamped Python support, which allows users to directly access, modify, and create JMP data tables from Python. This is accomplished through the jmp.DataTable Python object.  Keep reading to learn how to create a pandas.DataFrame from a JMP data table, as well as the reverse, a JMP data table from a pandas.DataFrame live and in-memory.
    Paul_Nelson Paul_Nelson
    JMPer Cable |
    Mar 25, 2025 1:22 PM
    2713 views | 1 replies
  • Nuevas funcionalidades de JMP 18 (video en español)
    Esta presentación introduce las nuevas funcionalidades de JMP 18 en español, incluso:   Detección de picosConectores de datos configurablesMejoras la importación de datos en servidores PIPreajustes de plataformaMejoras en le perfilador de predicción, incluso visualizar los intervalos de predicción, las interacciones superpuestas, y la habilidad de ver las observaciones individuales.Mejoras en la i...
    MarilynWheatley MarilynWheatley
    JMP Blog |
    Mar 25, 2025 6:03 AM
    657 views | 1 replies
    No supplied image
  • Outliers Episode 4: Detecting outliers using jackknife distance
    The jackknife technique is very simple, yet very powerful, relying on calculations using the “leave one out” technique.Figure 3: Simple plot of X1 vs X2, including best-fit line (from ordinary least squares)
    JerryFish JerryFish
    JMP Blog |
    Mar 20, 2025 2:34 PM
    14764 views | 3 replies
  • Three JSL Easter Eggs
    drawing programlook in the scripting index, under MouseBox.  The sample script for SetClick is a tiny sketchpad.15-puzzlewhile you are looking at MouseBox, check out the SetDropTrack script.  Classic game.mazeAlong with the other samples that ship with JMP, there is a set of 3D samples.  Look in Samples/Scripts/Scene3D.  Check out the RatMaze JSL sample.  (Read the 2nd paragraph of the comments be...
    Uncharted |
    Mar 19, 2025 2:03 PM
    3310 views | 2 replies
  • 近年のバージョンアップで追加された「効果量」の表示機能 ~その用途と活用法~
    近年のJMPのバージョンアップ において、最新版のJMP 18ではt検定における効果量「Cohenのd」(Cohen's d)を、JMP 17以降では回帰分析における効果量「η2」(イータ2乗)、「ω2」(オメガ2乗)を出力できるようになりました。     効果量とは、統計モデルにおける説明変数(要因)が目的変数に与える影響の大きさを示す指標です。要因が(偶然ではなく)目的変数に影響を与えているかを示す指標としてp値がありますが、これは統計的な有意性を判断するものであり、効果の大きさを示すものではありません。   JMPでは「モデルのあてはめ」のレポートとして、以下の「効果の要約」が表示されます。このレポートでは、p値が小さい順(対数価値が大きい順)に並びますが、これは性別、薬、性別*薬の順に効果が大きいことを直接示すわけではありません。あくまで統計的な有意性の大きさを示しています。  ...
    Naohiro Masukawa |
    Mar 18, 2025 5:00 PM
    363 views | 0 replies
