Blogs
Read about a broad range of data analysis topics and posts that inform your JMP use.
Latest Posts
  • Master List – Pictures from the Gallery – Advanced Graph Building Series
    Pictures from the Gallery – Advanced Graph Building Series Links, Snapshots, and Graphs Featured
    scwise scwise
    Scott Wise's Blog |
    Nov 7, 2025 5:56 AM
    3871 views | 1 replies
  • JSL to make a video from AI images
     I started this project by making a collection of 13,000 512x512 AI images. The next step is to load some meta data about the images into a data table.  Later I'll be choosing images with similar colors to replace parts of a zoomed in image. The table looks like this: The H,L,S and R,G,B values match the swatch color. The color should match some color in the sample. This loads the filenames, but n...
    Craige_Hales Craige_Hales
    Uncharted |
    Nov 6, 2025 8:48 AM
    75 views | 2 replies
  • DoE_Approaches.svg
  • Using dates, times, datetimes and durations in JMP
    There are four common time-based values that you might have to deal with in JMP: dates, times, datetimes and durations.
    Jeff_Perkinson Jeff_Perkinson
    JMPer Cable |
    Oct 28, 2025 8:26 AM
    48518 views | 1 replies
  • New in JMP Clinical 19
    The latest release of JMP Clinical makes it the most sophisticated visualization and analysis tool for clinical trials the market. It has as much to do with our teams that build the software as it does its amazing functionality. Building on the powerful functionality of JMP Pro, JMP has delivered a solution that addresses the needs of a wide audience, including safety surveillance teams, medical m...
    geoffrey_mann geoffrey_mann
    JMPer Cable |
    Oct 14, 2025 7:34 AM
    2141 views | 1 replies
  • Unlock dynamic data stories: Tips for publishing on JMP Public
    If you’re looking to make your data stories and presentations shine, forget static images and boring slides. JMP Public is a high-impact platform that showcases the dynamic, interactive power of JMP visualizations.   Here are a few best practices to follow when posting:   Enhance post interactivity and engagement If possible, share a report that will be interactive in JMP Public, such as a visuali...
    dieter_pisot dieter_pisot
    JMP Blog |
    Oct 10, 2025 10:11 AM
    424 views | 0 replies
  • 20 years at the movies through ticket stubs
    In many ways, movies can catalog the history of your life, just as your books, music collection, concert tickets, or comics might. There is a story there of what your interests were at the time, who you saw them with, and what they meant to you. I thought it would be an interesting trip down memory lane to gather up these tickets, enter them into JMP, and explore the data. Plus, with paper tickets...
    josh_markwordt josh_markwordt
    JMP Blog |
    Oct 9, 2025 1:53 PM
    9116 views | 6 replies
  • Understanding simple mediation analysis in JMP Pro
    When two variables are related, the natural next question is “why?” Mediation analysis helps answer that by testing whether a third variable, the mediator, explains how the predictor influences the outcome. It moves us from “X is related to Y” to “X affects Y by changing M.” For example, in education research, we might find that students who feel a strong sense of belonging are more interested in ...
    Hamid_Sanei Hamid_Sanei
    JMPer Cable |
    Oct 9, 2025 6:00 AM
    232 views | 0 replies
  • こんなこともできる!「JMP 19」の新機能 ~ その2. 「Games-Howell検定」:等分散性を仮定しない平均の比較 ~
    最新バージョン「JMP 19」では、「二変量の関係」プラットフォームの「一元配置分析」(Yに連続尺度、Xに名義・順序尺度を指定)のレポートにおいて、「Games-Howell検定」による平均の比較を行うオプションが追加されました。     ----------------------------------------------------------------------------------------------------------------- Games-Howell検定(JMPのホバーヘルプの説明より) すべてのペアの平均を比較する検定であり、また「各グループの誤差分散がすべて等しい」と仮定できない状況に対処した検定である。 -----------------------------------------------------------------------...
    Masukawa_Nao Masukawa_Nao
    Naohiro Masukawa |
    Oct 8, 2025 9:05 PM
    423 views | 0 replies
  • Jet theme
    Jet is the 3rd Chromatic theme.
    Uncharted |
    Sep 29, 2025 5:35 PM
    281 views | 1 replies
  • こんなこともできる!「JMP 19」の新機能 ~ その1. 「多重応答」を使ったフィルタリング、集計 ~
    ついに、新しいバージョン「JMP 19」がリリースされました!   もちろん「JMP 19」ではさまざまな機能が追加されています。主な新機能やアピールポイントについては、別のブログポストで紹介されています(原文は英語)。   そこで私の方では、あまり大々的にアピールはされていないけども、ユーザにとって便利で有用だと思える機能を数回にわたり紹介していきます。   第1回となる今回は、消費者調査や満足度調査などで役立つ「多重応答」についての新機能を取り上げます。JMP 19では「多重応答」列を用いたフィルタリング、集計表の作成ができるようになりました。     多重応答とJMPの設定 多重応答とは、アンケート調査などにおける「複数回答」(当てはめるものをすべて、あるいはいくつか選択して回答する形式)に対応するJMPの尺度やプロパティです。   下図は、ある企業研修のアンケートの回答をまとめた...
    Naohiro Masukawa |
    Sep 23, 2025 7:27 PM
    917 views | 0 replies
  • More on the many advantages of structural equation models
    Ken Bollen: The many advantages of structural equation models
    anne_milley anne_milley
    JMP Blog |
    Sep 16, 2025 5:58 AM
    1231 views | 0 replies
  • 変量効果モデルによる「室内再現精度」と「併行精度」の算出 ~医薬品開発における精度の評価~
    本記事では、医薬品開発における精度評価で用いられる「室内再現精度(Intermediate precision)」と「併行精度(Repeatability)」をJMPを用いて算出する方法を例題に沿って説明します。   この記事を書くきっかけとなったのは、最近公開した小野薬品工業株式会社様のユーザー事例 です。この事例の中では、室内再現精度や併行精度の評価方法として、制限付き最尤法(REML)を用いて分散成分を推定するといったコメントがあります。   この事例をご覧になったユーザーから「この方法を詳しく説明してほしい」という要望をいただいたため、本記事を執筆することにしました。   室内再現精度と併行精度とは ここでいう「精度」とは、同一試料(検体)を複数回測定した際の測定値間のばらつきを評価することを指します。   医薬品のガイドラインである「ICH-Q2  分析法バリデーション」では、次...
    Naohiro Masukawa |
    Sep 15, 2025 4:42 PM
    1277 views | 2 replies
  • See the latest in the JMP Marketplace
    JMP Marketplace is an online platform to help you extend JMP as your needs evolve. Like other app stores, JMP Marketplace offers a curated selection of fully tested applications, add-ins, data connectors, and other extensions that enhance and expand JMP’s powerful capabilities.   Watch a demo of the Marketplace here.
    kristen-slappey kristen-slappey
    JMPer Cable |
    Sep 12, 2025 9:36 AM
    1882 views | 0 replies
    No supplied image
  • Choosing estimators in the Causal Treatment platform
    When treatment is binary, the Causal Treatment personality in JMP enables you to choose between four estimation techniques: inverse probability weighting with ratio adjustment (IPWR), regression adjustment (REGADJ), augmented inverse probability weighting (AIPW), and propensity score matching. You may be comfortable with one of these estimation methods, or you may have no idea where to begin. Alon...
    MeichenDong MeichenDong
    JMPer Cable |
    Sep 12, 2025 9:31 AM
    2075 views | 0 replies
    No supplied image
  • From correlation to causation: The Causal Treatment platform
    Randomized controlled trials (RCTs) and other carefully designed statistical experiments are the gold standard for answering questions about cause and effect. Randomly assigning experimental units (for example, participants in a clinical trial) to treatment and control groups balances the two groups so as to minimize the chance of substantive differences between them other than those caused by any...
    JMPer Cable |
    Sep 12, 2025 9:30 AM
    2178 views | 0 replies
  • JMP 19: What's new in data connectors
    Data access is fundamental to JMP. For the last several releases, we've been building infrastructure so that you can access data efficiently, regardless of where it lives. Once you to get the data you need into JMP, you can begin answering the questions you have. Every version of JMP adds new efficiency gains, performance improvements, and workflow additions. JMP 19 continues that trend.
    Prefer vi...
    willmorgan willmorgan
    JMPer Cable |
    Sep 12, 2025 9:20 AM
    2715 views | 0 replies
  • New in Graph Builder for JMP 19
    JMP 19 brings many improvements for Graph Builder. Here are a few of the most significant additions. Constrained smoothers The smoother element has a new method called P-Spline. It’s a cubic spline, just like the existing Spline method, but it’s parameterized in a way that better supports constraints. Monotonic trend curves are the most requested smoother feature, and now it’s possible – and then ...
    XanGregg XanGregg
    JMPer Cable |
    Sep 12, 2025 9:09 AM
    2924 views | 10 replies
  • What’s new in JMP DOE
    JMP’s latest release brings a fresh wave of updates to the Design of Experiments (DOE) platform, with new tools and smarter workflows that make it easier to design, simulate, and explore experiments. Whether you're screening factors, simulating responses, planning sample sizes, or trying to pinpoint the root cause of a failure, there’s something new to try out. Smarter fault localization with Baye...
    Ryan_Lekivetz Ryan_Lekivetz
    JMPer Cable |
    Sep 12, 2025 9:08 AM
    2196 views | 1 replies
