Add-In Guidelines
Add-in guidelines are intended to ensure consistency and integrity with the add-ins available in the File Exchange. Use best practices for scoping and namespaces. Review the “Advan...
Ryan_GilmoreAdd-in guidelines are intended to ensure consistency and integrity with the add-ins available in the File Exchange. Use best practices for scoping and namespaces. Review the “Advan...
Ryan_GilmoreHere is an add-in to allow people to generate and select OMARS experimental designs for 5, 6 or 7 factor experiments. The add-in was presented at the 2022 JMP Discovery Summit Europe, OMARS Designs A...
HadleyMyersNew for JMP 17 Pro: An Autotune option makes it even easier to automatically tune hyperparameters using a Fast Flexible Filling design. The XGBoost add-in for JMP Pro pro...
russ_wolfingerDescription The Word Import Tool add-in allows you to import text, tables, or images from a Word document. It can also create a table summarizing one or more Word documents. Laun...
Justin_ChiltonThis addin contains several utilities for working more efficiently with data tables. With it, you can: Quickly set the number of decimal places displayed in the data table. Set and cha...
brady_brady(18Aug2019) - A note from the author Hi, All! It's time to start thinking about a new version of the STK... I've got some things that I'd like to do, but I also want to hear from those using ...
MikeD_AndersonHow can JMP Technical Support help you? To make reaching out to Technical Support easier for you, we have created the Contact JMP Technical Support Add-In. This Add-In will open...
Justin_ChiltonThe Journal Text Sledgehammer is a tool for bulk formatting of TextEditBoxes within journals. To use: Open the Journal(s) you want to edit. If no journals are open, the p...
brady_bradyPurpose The Torch Deep Learning Add-In for JMP® Pro provides a no-code interface to the popular Torch library for predictive modeling with deep neural networks. T...
russ_wolfingerこのアドインについて このアドインは、JMPのガウス過程モデルを利用して、ベイズ最適化を行うためのアドインです。 システム要件 JMP 15以降 表示言語は、英語および日本語のみ ベイズ最適化について ベイズ最適化は、逐次的な実験を繰り返し行い、最適解を探すときに使用される手法の一つです。ベイズ最適化の主な流れは、次の通りです。...
yuichi_katsumurPurpose This add-in uses JMP mixed model platform to do stability / shelf-life analysis while considering random batches. Statistical details for the analysis are found here: Mixed model stab...
MikeD_Anderson(18Aug2019) - A note from the author Hi, All! It's time to start thinking about a new version of the STK... I've got some things that I'd like to do, but I also want to hear from those using ...
MikeD_AndersonThis add-in summarizes values by category and produces waterfall charts. (Add-in updated by Brady Brady BradyBrady August 28, 2015.)
brady_bradyThe purpose of this add-in is to assist in the migration of JMP Clinical configurations and studies (from source versions 7.0 through 8.1 to target versions 17.0 through 18.0 on Windows OS). It use...
john_cromer...enn and Euler Diagrams”, available at http://www.cs.uic.edu/~wilkinson/Publications/venneuler.pdf The corresponding computations are performed in Java, so you must have Java installed on your m...
russ_wolfingerPurpose The Capability Explorer add-in provides an interactive, six-graph summary for evaluating process capability. The report provides a process capability analysis and allows users to e...
scott_allenThis tool allows user to fill missing values based on previous/next/nearest found value.There are already tools which can do this in a way or another (even JMP has fill rows), but the ones I have use...
jthiこのアドインについて マテリアルズ・インフォマティクス(MI)、ケモ・インフォマティクスのためのアドインです。マテリアルズ・インフォマティクスは、材料の開発や探索をより効率的にするために、機械学習などの情報科学の技術を活用する取り組みです。 分子を機械学習で扱う際の課題は、分子をコンピュータが解釈できる数値にどう変換するか、という点です。その一つの解決策として「フィンガープリント」があり...
yuichi_katsumurPurpose This add-in is designed to produce an attractive graphical rendition of a process capability study, and to make it easy to perform analyses across multiple columns of data. How t...
David_BurnhamThe acceptance sampling plan add-in provides a point-and-click interface for generating / creating, evaluating and comparing sampling plans. Specifically, one can create sampling plans by lot accep...
stan_koprowskiPurpose This add-in provides a needed bridge between the capabilities of the Nonlinear/Fit Curve platforms and Functional Data Explorer. It is designed to handle common spectroscopic tasks li...
MikeD_AndersonThis Add-In allows you to define and check the physical units of your columns and then convert them to different units. For example, define a column in milliliters/hectare and then convert it, a...
EvanMcCorkleThis add-in contains tools for the analysis of data from Electrochemical Impedance Spectroscopy (EIS). It wraps functionality from the Python Package Impedance.py. After installing the add...
Jordan_HillerThe Documentation add-in installs the individual PDF files for all JMP books, and the Documentation Library, which is a concatenation of all the books into one PDF. The add-in also installs a new men...
Qiana_EaglinThe Documentation add-in installs the individual PDF files for all JMP books, and the Documentation Library, which is a concatenation of all the books into one PDF. The add-in also installs a new men...
Qiana_EaglinPurpose Here is an attempt of my first application built with app-builder using the connection between JMP and Python to handle a complex machine learning algorithm. The purpose of this app is to...
Franck_R
