aaarnm
Wrongly calculated boxplots for binned data
Hi!
I have binned my data and want to plot it in boxplots now, the problem is that the values that come out are not at all in the scale of Y. Does anyone know what could be causing this?
Re: Wrongly calculated boxplots for binned data
You need to change the modeling type of your Binned column from continuous to nominal, and then go into the Axis Settings for the Y axis and change the scale.
aaarnm
Hi Jim! It was apparently already set on nominal... So there must be something else wrong
It would be helpful if you could create a sample data table, save the graph builder script to the sample table, and then attach the table to a response to this discussion
