This version requires the user to commit the changes to the number.
Names Default to Here( 1 );
last = eon = 0;
New Window( "Only Seven",
Outline Box( "Enter EON",
Line Up Box( N Col( 2 ),
Text Box( "System EON:" ),
neb = Number Edit Box( eon,
<< Set Integer Only( 1 ),
<< Set Minimum( 0 ),
<< Set Tip( "Enter an integer number with no more than 7 digits"),
<< Set Function( // called when user commits data entry
Function( { self },
new = self << Get;
If( Length( Char( new ) ) > 7,
self << Set( last ),
last = new
nw = New Window("Example",
Lineup Box(N Col(2),
Text Box("Set to max value on COMMIT:"),
Number Edit Box(
, 10
, << Set Maximum(9999999)
, << Set Exclude Maximum(0)
, << Set Integer Only(1)
Text Box("Set to last COMMITTED value on COMMIT:"),
cb = Context Box(
box:last_val = .;
Number Edit Box(
, 10
, << Set Function(function({this},
If((this << get) >= 10000000,
this << set(box:last_val)
box:last_val = this << get;
Text Box("Throw on COMMIT"),
cb = Context Box(
box:last_val = .;
Number Edit Box(
, 10
this << set(box:last_val);
Throw("No values longer than 7 digits allowed");
Text Box("Set to last changed value on change and break focus:"),
cb = Context Box(
box:last_val = .;
Number Edit Box(
, 10
, << Set Number Changed(function({this, val},
If((val) >= 10000000,
box:mb << Set Focus(1); // to break focus from number edit box
box:last_val = val;
Unlineup Box(box:mb = Mouse Box());
last = eon = 0;
Function( { self, number },
If( Length( Char( number ) ) > 7,
last = number
I modified the code as shown below, but still no success. Do you think its a big in JMP software?
last = eon = 0;
last = number
<< Set Max Length(7) // Limit the number of digits to 7
This is a modified version of the example of set number changed() and get number changed() in the Scripting Index. I think this gets you pretty close to your target:
New Window( "Example",
numBox = Number Edit Box(
10,
<< set number changed(
Function( { thisBox, value }, /* put my value into my sibling's display */
if( length( char( value ) ) > 7,
// > 7 digits
thisBox << set( . );
( thisBox << sib ) << settext( "Too many digits" ),
// <= 7 digits
( thisBox << sib ) << settext( char( value ) )
Text Box( "" )/* here's the sibling box, waiting to show a message */
numBox << get number changed()
last = eon = 0;
Function( { self },
new = self << Get;
last = new
Number Edit Box(
, 10
cb = Context Box(
box:last_val = .;
Number Edit Box(
, 10
cb = Context Box(
box:last_val = .;
Number Edit Box(
, 10
cb = Context Box(
box:last_val = .;
Number Edit Box(
, 10
box:last_val = val;
