RA899
Running Python script using JSL [Permission Error]
I'm trying to run a jsl script that does several things. One of them is to run an external python script. When I run the python script which does some modifications to an excel file, it gives me an error message indicating that permission is denied to access/write on the excel file. Please note that when I run the python script separately, it works like a charm.
How can I give jmp the proper permission? thanks. The code im using is below.
x = RunProgram(
	executable( "python" ),
	options( "C:\Users\user1\Desktop\temp.py" ),
	readfunction( "blob" )
RA899
Re: Running Python script using JSL [Permission Error]
Never mind. The problem was in the code itself. I needed to provide the full path for a sub-routine.
RA899
RA899
In the python code**
