Françoise
Pb graph HTML
I have not the value of the point in the label.
Is this normal? see the Y axis, the value is low...
Françoise
Re: Pb graph HTML
if my Y axis has no value in %, I have the displayed value.
Pb with%?
Re: Pb graph HTML
Hi @Françoise,
That looks like an issue with formatting the value when it is reported as a %.
Please try increasing the Width value in the Format in the Y Axis Settings to see if that resolves the problem.
~John
