BrianK
Passing a variable into a cusum chart
Hi there,
In the simple script below, how do I pass the variables varTarget and varSigma into the cusum creation?
dt = Open( "$SAMPLE_DATA/Quality Control/Engine Temperature Sensor.jmp" );
varTarget = 100;
varSigma = 10;
dt << CUSUM Control Chart(
    Y( :Y ),
    Target( varTarget ),
    Sigma( varSigma ),
        Dispatch( {"CUSUM Chart"}, "2", ScaleBox, {Min( -7.5 ), Max( 10 ), Inc( 5 ), Minor Ticks( 1 )} )
Re: Passing a variable into a cusum chart
I thought that I could use Eval Expr() function with the variables as arguments but it didn't work here. Anyway, I usually use this approach based on substituting parts of an expression.
varTarget = 100;
varSigma = 10;
Eval(
	Substitute(
		Expr(
				Y( :Y ),
				Target( ttt ),
				Sigma( sss ),
		Expr( ttt ), varTarget,
		Expr( sss ), varSigma
ih
ih
Here is how to do it with Eval Expr:
Eval(Eval Expr(
		Y( :Y ),
		Target( Expr( varTarget ) ),
		Sigma( Expr( varSigma ) ),
This link shows a few other methods to do the same thing.
