BookmarkSubscribeRSS Feed
Can I put two graphs from two data tables into one page
The jsl below doesn't work. Any suggestions?
V List Box(
tbl1 = ("C:\table1.jmp")
tbl1 << Scatterplot Matrix(
Y( :age ),
X( :height ),
tbl2 = ("C:\table2.jmp")
tbl2 << Scatterplot Matrix(
Y( :age ),
X( :height ),
ms
Super User ms
Re: Can I put two graphs from two data tables into one page
Your script does not make much sense to me but it is possible to put two graphs into one page using << journal.
plot1=tbl1< Y( :age ),
X( :height )
plot2=tbl2< Y( :age ),
X( :height )
plot1<plot2<
If you don't mean "page" as in page, but rather a custom report, then I think you must define the variables for the tables and individual reports outside the VListBox-object. Thereafter you can use your reports or elements within them to make a custom report.
Thanks a lot!
The following is the jsl I'm using and it doesn't work. Why?
wind = New Window( "Agency Analysis Window",
V List Box(
plot1 = Agency_submission << Scatterplot Matrix(
Y( :Success ),
X( :Submission )
plot2 = Agency_subm&Rev << Scatterplot Matrix(
Y( :Success ),
X( :Submission )
plot1 << journal;
plot2 << journal;
mpb
Super User mpb
What do you mean by "it doesn't work"?
ms
Super User ms
You do not need the << journal commands if you indend to use the NewWindow-command (the << journal creates a new window automatically, unless you already have a journal open), and in anyway I don't think you can use <
Try this (the <
dt=datatable("name of your data table");
V List Box(
plot1 = dt << Scatterplot Matrix(
Y( :Success ),
X( :Submission )),
plot2 = dt << Scatterplot Matrix(
Y( :Success ),
X( :Submission ))
Wind<
This works perfectly! Thanks a lot MS!
