rk2018
Accessing Parent Module Objects from Child Module
Hi
I am working on developing a Analysis Tool using JMP Application.
As part of it, I am opening a Child module(type:dialog) instance and passing values needed from Parent module to Child using Create Instance({}) construct.
Now I want to Manipulate the parent module's Text box with value entered on Child module'sText Edit box when child module is closed.
How can I access parent module's Text box variable from Child module's script?
(I cannot convert the child module to Modal dialog as users need to access data tables while they were on the child module.)
I am new to JMP and any links/pointers on this one will be helpful.
Regards,
Ravi Kumar
