darshanhira
Darshan Hiranandani - How can I transfer a variable value from JMP into Python?
Hi, Hey everyone, I am Darshan Hiranandani, I am looking for some advice on transferring a variable value from JMP into Python. Does anyone have any suggestions on how to achieve this?
Re: Darshan Hiranandani - How can I transfer a variable value from JMP into Python?
the Python Send() function will pass a JMP Variable to Python
Here is an example
x = 2;
Python Send( x );
Python Submit( "print(x)" );
See the JMP Help webpages and the Scripting Index for further documentation.
If you are running JMP 18, there is an embedded installation of Python which allows Python programs to be run in conjunctions with JMP.
hi,
txnelson is right as always ;)
for the JMP 18 way a look into the documentation is also an option:
https://www.jmp.com/support/help/en/18.0/#page/jmp/python-name-and-python-send-examples.shtml
/****NeverStopLearning****/
