lala
Level IX
Can JSL modify the system "Preferences" of JMP?
Now "Wrap text" is not selected in "Script Editor" in JMP's system "Preferences".
Can a JSL be used to open the edit state of a given JSL and hologram it to be able to "Wrap text"?
Thanks!
lala
Level IX
回复: Can JSL modify the system "Preferences" of JMP?
dz = Open( "$SAMPLE_Scripts\demoLong.jsl", Add to Recent Files( 0 ) ,"Wrap text");//??
It will be a change to preferences so do NOT let anyone run this script who doesn't want that preference to be changed
Set Preferences(Script Editor Settings(Wrap Text(0)));
https://www.jmp.com/support/help/en/17.2/#page/jmp/utility-functions.shtml?os=win&source=application...
Provide way to set session / instance preferences and presets
lala
Level IX
Thanks Experts!
OK, the command doesn't work until version 17.
It should be same command for JMP16 and 17 (at least it works form me in both). You can also change the setting manually from preferences and use Get Preferences() to get an idea of the command which you should use when you set them (JMP might not show default settings when using that).
