hogi
Level XIII
Jmp Update & Python
Up to now, my Python distribution was separate from Jmp.
So, after an Update of JMP the Python installation was still the same - with all packages.
With JMP18 I understood that Python comes directly with Jmp.
What happens after a Jmp upgrade? Will the Python packages be automatically installed in the new JMP version?
lala
Level IX
回复: Jmp Update & Python
  • Unfortunately, JMP 18 is not yet available for trial download.
Re: Jmp Update & Python
Hi hogi,
here you find how to include packages: https://www.jmp.com/support/help/en/18.0/#page/jmp/install-python-packages-in-jmps-python-environmen...
in case you have a compiled one: https://www.jmp.com/support/help/en/18.0/#page/jmp/install-compiled-python-packages-using-the-comman...
The jmputils.create_jpip() function creates the terminal or command shell version of the jpip script within the directory specified. The jpip script is a wrapper for the Python pip command. It ensures the appropriate environment variables are configured and packages are installed to the JMP site-packages directory.
jmputils.jpip('pip_cmd', packages='string')
The jmputils.jpip() function wraps the Python pip command. Pass the desired pip command as a string, and optionally a space-delimited string of packages to install. The packages argument defaults to an empty string.
More information can be found in the documentation as well :)
/****NeverStopLearning****/
hogi
Level XIII
Hi Martin,
thanks for the info how to install packages.
If this is an answer to the original question, it's kind of implicit:
One has to manually install the (old) packages with every update?
also for "small" updates like 18 -> 18.1?
