eliyahu100
Tabulate all numeric columns in a table
I'm trying to creat a tabulate table that cill contain all numeric columns (and then another one with the categorical ones).
I tryed running this but it doesn't work.
Any suggestion?
TIA
	NumericCols = {};
	for(i = 1, i <= N Cols(dt), i++,
		Col = Column(dt,i);
		ColDataType = Col << Get Data Type;
		If( ColDataType == "Numeric",
			Insert Into(NumericCols,Col << Get Name);
Tabulate(
	Set Format( Uniform Format( 10, 2 ) ),
	Add Table(
		Column Table( Statistics( N ) ),
		Column Table( Statistics( Mean ) ),
		Column Table( Statistics( Std Dev ) ),
		Column Table( Statistics( Min ) ),
		Column Table( Statistics( Max ) ),
		Column Table( Statistics( Median ) ),
		Row Table(
			Analysis Columns(
				NumericCols = {}
10 REPLIES 10
Re: Tabulate all numeric columns in a table
By mistake, I edited the above question and changed the question to my response.  @eliyahu100  I apologize for my mistake.
