JMP Knowledge Base
Featured Items
Latest Posts
  • Deploying JMP Student Edition
    The purpose of this document is to learn about the JMP Student Edition software, describe the process for obtaining the JMP Student Edition installer, and provide guidance on how to deploy the JMP Student Edition installer within a university computer laboratory or a university classroom from the perspective of an IT computer administrator.   Quick Links What is JMP Student Edition? How to downloa...
    stan_koprowski stan_koprowski
    JMP Knowledge Base |
    Sep 17, 2025 6:12 AM
    10190 views | 0 replies
  • Control Chart Builder Dispatch commands that were created in JMP® 18 and earlier are incompatible with JMP® 19
    In JMP® 19, the underlying syntax for dispatch commands related to the subgroup axis was changed. Consequently, such dispatch commands created in JMP 18 and earlier are incompatible with JMP 19. Running a script with an incompatible dispatch command in JMP 19 produces a "Cannot find ScaleBox" error.   There is no workaround for this behavior. A new JSL script containing updated syntax must be gene...
    sseligman sseligman
    Sep 16, 2025 11:27 AM
    14 views | 0 replies
  • JMPで複数のROC曲線の比較やAUCの信頼区間の表示は行えますか?
    JMP Pro 10以上では、ロジスティック回帰において、確率の計算式を保存して[モデルの比較]プラットフォームを用いることにより可能です。 実行例
    下記のデータに対し、「(1)Y: 「Popid」、X:「alb」のROC曲線」、「(2)Y:「Popid」、X:「tp」」のROC曲線の2つを比較(いずれもPopid=1を陽性に指定)   (1)、(2)それぞれに対し、[二変量の関係]または[モデルのあてはめ]からロジスティック回帰を実行し、レポートの赤い三角ボタンから[確率の計算式の保存]を選択します (区別のために、確率[1]の列名を、「確率[1]alb」, 「確率[1]tp」と変更しています)。   [分析]→[予測モデル]→[モデルの比較]を選択し、「確率[1]alb」、「確率[1] tp」を[Y,予測子]に指定して[OK]をクリックします。レポート「モデルの比較」の左上にある...
    Ryan_Gilmore Ryan_Gilmore
    Sep 15, 2025 7:45 PM
    1395 views | 0 replies
  • Manual Authorization of JMP®
    The following guide provides a method to authorize JMP® on non-networked (air-gapped) machines. The most current version of JMP can be downloaded from My JMP.   Step 1) Launch JMP
            Step 2) JMP will detect no internet connectivity and request manual authorization. Click the Copy Request Code to copy it from the Authorization window.
            Step 3) Navigate to jmp.com/authorize on an inter...
    Bobby_Riggs Bobby_Riggs
    Sep 15, 2025 1:53 PM
    5357 views | 2 replies
  • How to Create Physical Media for JMP® Software
    All JMP® software is provide through My JMP. JMP will no longer ship physical media as an option. Customers who cannot download the software due to security policies will need to download outside of their firewall or have a member of their IT team or consultant do it for them.  With the installer downloaded, you can save the files to a USB Drive or burn them on to a DVD.   This JMP Note will provi...
    Dave_Matthews Dave_Matthews
    Sep 15, 2025 12:31 PM
    1001 views | 0 replies
  • JMP® New Features and Release Notes
    JMP® 19:
    New in JMP 19     JMP® 18:
    Release Notes for JMP/JMP Pro 18.x      JMP® 17:
    New Features for JMP 17 Release Notes for JMP/JMP Pro 17.1 Release Notes for JMP/JMP Pro 17.2   JMP® 16:
    New Features for JMP 16 Release Notes for JMP/JMP Pro 16.1 Release Notes for JMP/JMP Pro 16.2   JMP® 15:
    New Features for JMP 15 Release Notes for JMP/JMP Pro 15.1 Release Notes for JMP/JMP Pro 15.2.1
    JMP® 14:
    New Fea...
    Sep 15, 2025 11:46 AM
    17796 views | 2 replies
  • Supported Operating Systems by JMP® Version
    The following table describes the operating systems supported by JMP version and release. The term 'JMP' refers to: JMP, JMP Pro, and JMP Clinical.
    JMP Live can only be installed on Windows Server OS (*).   JMP Version/Release Supported Operating System JMP 19 Windows 11 Windows 10 (version 1809/build 17763 and above) no support for 10 S edition or tablet mode Windows Server 2025 * Windows Se...
    Sep 15, 2025 11:02 AM
    3299 views | 0 replies
  • How to completely remove all system and configuration files from JMP for Windows
    Background
    It is sometimes necessary remove all JMP files from a system. Follow the steps here to completely remove all JMP system and configuration files from a Windows system. Note: The steps below require full administrative rights. If you do not have full administrative rights on your computer, you will need assistance from your IT team.
    Steps
    Uninstall JMP
    Navigate to Control PanelFrom the Pr...
    Sep 15, 2025 5:12 AM
    4555 views | 0 replies
  • Adding custom files to a JMP installation package
    The JMP administrator can add custom files to the JMP installation package. The JMP installer copies these files to your computer during the installation process. Once the files are installed, JMP processes these custom files. You can add the following types of custom files:       • Scripts (.jsl)       • Preferences (a JMP.PFS file)       • Add-ins (*.*)       • Samples (*.*)   Place the custom f...
    Sep 15, 2025 5:09 AM
    1844 views | 0 replies
  • The message "An error (-5001: 0x800700002) has occurred while running the setup" appears during a JMP® installation
    This error, which references “(-5001: 0x800700002),” is usually experienced under the following conditions: You attempt to run the JMP installer from a web browser, cloud-sharing site, or FTP site. You should download the file to your local machine and then perform the installation.You attempt to run the JMP setup.exe file from within a ZIP file without unzipping the files. You must first unzip th...
    Dahlia_Watkins Dahlia_Watkins
    Sep 12, 2025 10:23 AM
    1674 views | 0 replies
  • Preparing JMP® to Use the InstallShield Silent Installation Method For Microsoft® Windows
    This JMP Note provides the steps to Create, Install, and Remove JMP silently using the InstallShield Record commands.   Please note, we do not support the distribution of our software through SCCM, InTune, or other mass software delivery systems. These are packaging mechanisms that we cannot control, so we cannot support the installation of JMP via these methods.   For Microsoft InTune deployments...
    Sep 12, 2025 8:49 AM
    7022 views | 0 replies
  • Performance lags are experienced when typing, scrolling, using drag & drop in platforms, or display issues are found in JMP®
    Users might experience the following issues while using JMP: Lag when scrolling through JMP data tablesKeystroke recording lags when typing in various areas of JMPJournal drop-downs or preferences that overlapInability to click on items, or drag & drop within in platforms, such as Fit ModelInability to add columns or rows to JMP data tables These issues are typically experienced when: Running JMP ...
    Sep 5, 2025 6:19 AM
    2384 views | 0 replies
  • ソフトウェア管理者変更のリクエスト方法
    JMPのソフトウェア管理者を変更する場合、現在の管理者のMy JMPのページからそのリクエストを送信していただけます。 手順は以下のとおりです。   現在の管理者がブラウザでMy JMPのサイトを開き、ご自身のメールアドレスでログインする。
    「ソフトウェアを管理する」をクリックする。
    管理者を変更したい契約の製品の行にある「Manage」のリンクをクリックする。
    「Update Software Administrator」ボタンをクリックする。
    必要事項を英語で入力し(お名前も半角ローマ字で入力してください)、「次へ」ボタンをクリックする。
    →この時点でリクエストが送信されます。
    次の画面に表示されるケース番号(case number)を念のため控えておく。
    再度「次へ」をクリックし、製品の管理画面に戻る。
    現在の管理者のメールアドレスに、ケース番号をお知らせするメールが送信されます。また、その後弊社...
    KyokoTakenaka KyokoTakenaka
    Sep 2, 2025 9:36 PM
    766 views | 0 replies
  • In Chinese JMP® Clinical 18.2.2, the Multivariate Inliers and Outliers report produces an error when run on Chinese Nicardipine
    In Chinese JMP® Clinical 18.2.2, running the Multivariate Inliers and Outliers report produces the following error: This issue is resolved in Chinese JMP® Clinical 19.0.
    sseligman sseligman
    Aug 27, 2025 12:05 PM
    60 views | 0 replies
  • Error installing Python module: There was a problem confirming the SSL certificate.
    When installing some Python packages via JMP, users might encounter the error below. The error occurs when attempting to access a package repository behind corporate firewalls.   Could not fetch URL https://pypi.org/simple/pip/: There was a problem confirming the ssl certificate: HTTPSConnectionPool (host='pypi.org', port=443): Max retries exceeded with url: /simple/pip/ (Caused by SSLError(SSLCer...
    Aug 21, 2025 1:45 PM
  • Technical support services for single-user licenses of JMP® have now expired
    The single-user (shrinkwrap) license, and is activated with a serial number, is sold with one year of technical support services. At this time, technical support services for these licenses of JMP 15 and earlier have now expired. Additional functionality and new features have been introduced in the more recent versions, and we encourage you to test the latest version of JMP by downloading the 30-...
    Aug 13, 2025 7:53 AM
    411 views | 0 replies
  • FAQのカテゴリ
    承認(JMP 18以降)・My JMP JMP 18 ユーザー承認ガイド My JMPへのサインイン方法 ユーザーの管理方法 JMP 18のダウンロード方法 − ソフトウェア管理者用 JMP 18のダウンロード方法 − 承認されたユーザー用 初回のJMPの起動 JMP 18を使い始めるには(JMP 17以前のバージョンの利用者様向け) メールアドレスの検証完了時に「JMPの承認が確認できません。」のJMP警告が表示される。JMPの手動承認 [承認の解除...]の使用方法(JMP 18.2以降)JMP 18が起動に失敗する、もしくは、期限切れのライセンス情報を参照する場合の対応エラー: We can't log in the user. Please contact your administrator. が表示される。JMP警告「の承認が確認できません。トライアルを開始する...
    Aug 1, 2025 1:34 AM
    7460 views | 1 replies
  • JMP警告「の承認が確認できません。トライアルを開始するには、 jmp.com/trial を開いてください。」が表示される
    JMP(またはJMP Pro)を起動してメールアドレスの検証を完了した際に、以下のJMP警告「の承認が確認できません。トライアルを開始するには、 jmp.com/trial を開いてください。」が表示される場合があります。以下のJMP警告は、そのメールアドレスがソフトウェア管理者により承認済みの場合でも発生し得ます。   また、ネットワーク接続されていないマシンでJMPを起動した場合、以下のように、リクエストコードの先頭部分にJMPやJMPPROといった製品名が表示されず、-(ハイフン)で開始された状態となる場合があります。 ※上図のリクエストコードは、一部マスキングしております。   この事象は、JMP(またはJMP Pro)のインストール先のフォルダー内の一部のファイルが欠けている場合に発生します。この事象が発生する例として、WindowsのデスクトップフォルダをJMPのインストー...
    TKOGSWR TKOGSWR
    Aug 1, 2025 1:17 AM
    143 views | 0 replies
  • JMP System Sizing Support for JMP® Presentation Virtualization (PV) and JMP® for the Cloud Versions
    When installing JMP on a server, it is necessary to determine the minimum acceptable hardware requirements to support all the end users, installed applications, data storage and data analytics that will be consumed simultaneously, under network load, etc.  One must consider hard drive space, CPU cores, and RAM (memory) in the case of a physical environment.  Similarly, when configuring a virtual e...
    Jul 14, 2025 7:35 AM
    159 views | 0 replies
  • ModuleNotFoundError: No module named '_socket' error when installing Python Packages
    Issue Description
    The error occurs when installing some Python packages (modules) within JMP 18's Python environment. This is caused by the folder structure of JMP's Python environment.
    Resolution
    To resolve this error: Create a DLLs subdirectory under the parent folder where the JMP.exe lives. This will be either: C:\Program Files\JMP\JMPPRO\18 or C:\Program Files\JMP\JMP\18.Copy all the .pyd fil...
    Jul 14, 2025 7:31 AM
    229 views | 0 replies
  • ActualTech 5.1.12 Oracle ODBC driver causes Invalid Identifier error when importing data.
    Issue ActualTech 5.1.12 ODBC driver does not work well with JMP. When connecting to any Oracle database using this version of the Oracle-specific Actual Technologies driver the following error will be thrown.    [Actual] (Oracle Error (904) - ORA-00904: "T1". "WEIGHT"': invalid identifier   Workaround The workaround is to downgrade to the 5.1.11 version of their driver. This version will pull the ...
    Jul 14, 2025 7:29 AM
    136 views | 0 replies
  • Weekdays and Holidays report fails to generate in JMP Clinical 18.2.1 on Mac OS
    When launching JMP Clinical 18.2.1 on Mac OS, the JMP log shows this message: "WARNING: The Holidays data table could not be create/updated." exception_msg[1] = "Traceback (most recent call last): File \!"<string>\!", line 7, in <module> ModuleNotFoundError: No module named 'holidays' "(1, 2); "No RoleAssignments were made in the system.clinical.preferences file." Expr: hasStudyManagerRole = 1; Ru...
    sseligman sseligman
    Jul 10, 2025 11:52 AM
  • How should I cite JMP® software in a publication?
    The proper citation for JMP® Software is as follows, where <x> is the version of JMP being cited:   2025 JMP® <x>. JMP Statistical Discovery LLC, Cary, NC..   The proper citation for a JMP manual is found on the copyright page of the manual, which is generally the second page of the PDF file.   [Previously JMP Note 35282]
    Wendy_Murphrey Wendy_Murphrey
    Jun 19, 2025 12:18 PM
    10615 views | 1 replies
  • エラー: We can't log in the user. Please contact your administrator. が表示される。
    JMPの承認を行おうとした際に、1時間以内にあまりにも多くの回数の承認が試された場合は、以下のエラーが表示されます。 ※上図は一部マスキングされております。   このエラーを解決するには1時間お待ちいただき、承認を一度だけ試し、認証コードを含むメールが届くのをお待ちください。 ※承認を一度だけ試し、認証コードのメールが届かない場合、迷惑メールフォルダやメールの隔離場所等に認証コードのメールが届いていないかをまずはご確認ください。   注: このドキュメントは下記のJMP Noteの内容を元に作成しています。 JMP Note 857446 - We can't log in the user. Please contact your administrator.
    TKOGSWR TKOGSWR
    Jun 18, 2025 12:57 AM
    243 views | 0 replies
  • JMP 18が起動に失敗する、もしくは、期限切れのライセンス情報を参照する場合の対応
    JMP(JMP Pro) 18が起動しない、もしくは、誤ってキャッシュされた期限切れのライセンス情報を参照する場合、Windowsのレジストリ内に保持されている現在のJMP 18のライセンス情報を消去することが必要な場合があります。 一例ですが、ライセンスの更新手続きは完了していても、以下のように起動時に「JMPソフトウェアのライセンスは期限が切れています。」と表示される等の場合があります。   このような場合、以下の手順に沿ってライセンス情報をリセットし更新する必要があります。 ※JMP(JMP Pro) 18.2以降を使用中で、かつ、JMP(JMP Pro)が停止前で起動できる場合は、「承認の解除」の機能を使用し現在のライセンス情報を消去することも可能です。「承認の解除」の使用方法はこちらをご参照ください。   JMP(JMP Pro) 18のライセンスのリセット手順 1. ライセン...
    TKOGSWR TKOGSWR
    Jun 18, 2025 12:56 AM
    1076 views | 0 replies
