Creating JSL functions implemented in Python
You want to keep coding in JSL, but for a particular function, you know there's an easy way to write it in Python. So how do you create a JSL function...
Paul_NelsonYou want to keep coding in JSL, but for a particular function, you know there's an easy way to write it in Python. So how do you create a JSL function...
Paul_NelsonThe Materials Informatics Toolkit is a powerful, user-friendly JMP add-in designed to provide an interface for using the RDKit package to calculate de...
yuichi_katsumurFishbone diagrams can be phenomenally useful, but in general are a giant pain to draw. In this blog I'm digging in to an often forgotten "Diagram Pla...
Byron_JMPJMP 18 has a new way to integrate with Python. The JMP 18 installation comes with an independent Python environment designed to be used with JMP. In a...
SamGardnerIn previous blog posts, we talked about breaking down one aspect of the testing challenge, dealing with multiple inputs as a designed experiment where...
Ryan_Lekivetz对于研究人员来说,掌握更高效的数据分析方法、使用数据思维解决难题可以达到事半功倍的效果。JMP 学术团队一直在为此不懈努力。11月19日,JMP 应邀走进华东师范大学,携带丰富的行业应用案例,为华师大的师生们呈现了精彩的DOE案例分享。 JMP 数据分析顾问 Jacky Zhang 老师从...
Jing-APxJThis blog post shows a method to tune hyperparameters to improve your model performance, utilizing space filling DOE along with the new Python integra...
Peter_HershNovas Funcionalidade no JMP 18 Nesta série de videos você desenvolverá as competencias necessárias para usar as novas funcionalidades do JMP 18. Criam...
WesleySantosAs part of our ongoing series of blogs about testing software, we’re going to take a bit of a detour to revisit the fundamental principles of factoria...
Ryan_LekivetzNovas Funcionalidade no JMP 18 Nesta série de videos você desenvolverá as competencias necessárias para usar as novas funcionalidades do JMP 18. Criam...
WesleySantosI am excited about the Capability Explorer add-in, which is a featured extension on the JMP Marketplace! The inspiration for this add-in was based on...
scott_allen先日、日本のお客様向けに「JMPによるスペクトルデータ/クロマトグラムデータの多変量解析」というタイトルのセミナーを実施しました。 このセミナーは、タイトルの通りスペクトルやクロマトグラムデータを扱うニッチな内容だったため、参加者は少ないだろうと勝手に思っていました。しかし、想像を大きく覆すほど...
Masukawa_NaoJMPの「モデルのあてはめ」プラットフォームでは、回帰分析、分散分析、(名義、順序)ロジスティック回帰、一般化線形モデルなど、さまざまなモデルを構築することができます。 観測されたデータについて回帰モデルをあてはめたり、実験計画法で計画した実験データについて応答曲面モデルをあてはめたりする用途に...
Masukawa_NaoIn several recent discussions about using parametric tests the question of whether the data is normally distributed (or passes a goodness of fit test ...
Byron_JMPThis week, we launched the JMP Marketplace. Our goal? To create an easy place for JMP users to find valuable and exciting extensions, data connectors,...
Daniel_ValenteJMP® has a jpip wrapper that is just a thin wrapper around pip as such functionality, like installing packages via a requirements file, is fully suppo...
Paul_NelsonThere are many different working pieces to consider when you look at performance in JMP Live and interactive HTML. Reports with large data sets and co...
PaulSpychalaXan Gregg, Distinguished Engineering Fellow and data visualization expert at JMP
anne_milleyJMPの「プロファイル」機能では、予測モデルを視覚化して、因子(説明変数)を変更したときの応答(目的変数)の予測値の変化をインタラクティブに調べることができます。さらに、応答の最大化、最小化するような因子の値を見つける「最適化」の機能も搭載されています。 しかし、因子の値を無制限に調べてしまうと...
Masukawa_Nao
