Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMP® Marketplace
Blogs
Read about a broad range of data analysis topics and posts that inform your JMP use.
Latest Posts
  • JMP® Marketplace Feature: S3 Data Connector
    The JMP S3 Data Connector uses JMP's powerful Python integration to provide seamless access to Amazon Web Services (AWS) S3. You can configure your AWS credentials within the data connector editor and quickly import files that are compatible with JMP and are hosted on Amazon S3 remote connections. This integration streamlines data retrieval processes, enhancing your workflow efficiency when workin...
    LandraRobertson LandraRobertson
    JMP Blog |
    Feb 19, 2025 9:00 AM
    17 views | 0 replies
    No supplied image
  • Accessing SAS using JMP 18, Python, and SASPy
    Using the scripting environment and a python package called SASPy, JMP 18 can interface with SAS instances, import data sets, export data sets, and run SAS code.
    chrishesser chrishesser
    JMP Blog |
    Feb 19, 2025 6:00 AM
    118 views | 0 replies
    No supplied image
  • 如何高效提升原物料建模效率、降低實驗成本?定量構效關係 (QSAR) 性能優化 4 步驟
    在化工或材料企業工作的你,如何有效提升新材料研發效率、降低實驗成本?透過QSAR方法,化工工程師可將多水準類別因子轉換為連續因子,並利用主成分分析減少變因數量,降低實驗次數與成本。結合JMP的Custom Design與PLS建模,可快速建立高效預測模型,優化材料選擇與製程設計。了解如何運用數據分析提升研發效率,探索更多實驗設計與建模技巧!
    JMP_Taiwan JMP_Taiwan
    JMP Blog |
    Feb 18, 2025 5:00 PM
    67 views | 0 replies
  • Control de Procesos y Automatización del SPC con JMP Live: Una Guía Práctica
    Descubre cómo JMP y JMP Live pueden transformar la gestión de datos en tu empresa mediante la automatización del SPC y las alertas automáticas en gráficos de control.
    MarilynWheatley MarilynWheatley
    JMP Blog |
    Feb 18, 2025 5:58 AM
    84 views | 0 replies
    No supplied image
  • From Picture to Data: Extracting graph data from a picture into a JMP Table for analysis
    Have you ever needed to import the data contained in an image of a graph into JMP? It turns out JMP can do this rather easily. Read on to find out how.
    Jed_Campbell Jed_Campbell
    JMP Blog |
    Feb 14, 2025 2:28 AM
    1379 views | 2 replies
  • Eficiencia sin código: Automatiza con el Constructor de flujo de trabajo de JMP
    El constructor de flujo de trabajo de JMP permite grabar los pasos que se toman haciendo clic en la interfaz de JMP, para que el trabajo sea repetible, para que los pasos se puedan aplicar cuando hay datos nuevos, o el flujo de trabajo entero se puede compartir con otras personas.
    JMP Blog |
    Feb 11, 2025 1:22 PM
    194 views | 0 replies
    No supplied image
  • Optimizing Multiple Curves in the Functional Data Explorer
    Can JMP be used to model, compare, and optimize multiple curves at the same time? I've been asked this a few times in the last month, and (of course) the answer is "yes." Read on to find out how.  
    JMP Blog |
    Feb 7, 2025 2:07 PM
    982 views | 3 replies
  • Demystifying Factor Constraints
    Specifying constraints in a DOE can seem daunting, but it can be much easier than you imagine if you use some of the other tools in JMP to do the heavy lifting.
    JMP Blog |
    Feb 6, 2025 2:01 PM
    3281 views | 8 replies
  • Active Learning in JMP - Chris Gotwalt ENBIS Workshop
    Watch the recording of this workshop with Chris Gotwalt and Phil Kay.
    Phil_Kay Phil_Kay
    Phil Kay's Blog |
    Feb 4, 2025 5:24 AM
    600 views | 0 replies
  • Design evaluation of optimal designs
    Optimal designs use one of several optimality criteria based on the goal of the experiment. Using the design evaluation tools we can compare, and contrast designs based on the goal of the experiment. In each of the case studies below, the tools relevant for each experimental goal are explored.   Summary of practical goals and design evaluation tools I-optimal D-optimal Practical goal: Accurate ...
    O_Lippincott O_Lippincott
    JMPer Cable |
    Feb 3, 2025 2:01 PM
    343 views | 2 replies
    No supplied image
  • Writing JSL code dynamically
    Why doesn't my code work when I try to use a variable as an argument to ...?
    Jasean Jasean
    JMPer Cable |
    Jan 27, 2025 10:39 AM
    262 views | 1 replies
  • What are “optimal designs” and “optimality criteria”?
    JMP’s Custom Design platform allows experimenters to create custom-built designs for their specific experiment needs by constructing optimal designs. The custom designer generates optimal designs by seeking to maximize one of several optimality criteria using the coordinate-exchange algorithm. The coordinate-exchange algorithm constructs a starting design by selecting random values within the desi...
    JMPer Cable |
    Jan 23, 2025 11:30 AM
    485 views | 0 replies
    No supplied image
  • New features in JMP Clinical 18.1.2 and JMP Clinical 18.2
    JMP Clinical 18.1.2 (released on January. 21) and JMP Clinical 18.2 (which will be released in March) comes with several important features, including data quality reports, a configuration checking tool, autosaving and restoring the review builder templates.
    Valerie_Nedbal Valerie_Nedbal
    JMP Blog |
    Jan 22, 2025 9:53 AM
    580 views | 0 replies
  • 製造業品質提升指南:圖解FMEA失效模式分析與工具應用
    本篇文章深入探討如何運用JMP工具進行FMEA(失效模式與影響分析),有效管理製造業品質問題。了解多重回應、儲存格著色及Dashboard等功能如何助力品質分析與改進,讓失效分析更高效、更直觀。
    JMP Blog |
    Jan 22, 2025 5:43 AM
    432 views | 0 replies
  • 共変量を変化させたときの薬物動態モデルの考察
    下図は、12人の患者に特定の薬剤を投与した際の薬物濃度の時間経過を示す折れ線グラフです。薬物は投与後に体内で吸収され、濃度が急激に上昇した後、分布や代謝によって濃度が緩やかに低下します。このグラフは、薬物動態の基本的なパターンを示しています。 患者ごとの折れ線を観察すると、濃度の変化に個人差が見られます。この差異は通常、薬物の種類、投与経路、患者個々の特性(例:体重や代謝能力)などによるものです。   例えば、体重が大きい患者では分布容積が増加し、最大濃度(Cmax)が低くなる可能性があります。また、投与量や薬剤の種類によっても濃度推移が変化することがあります。   これら、薬物動態に影響を及ぼす可能性がある要素は「共変量」と呼ばれ、共変量の違いによって薬物濃度はどのように影響を及ぼすかを解析することがあります。   本ブログでは、JMP(JMP Pro) の「曲線のあてはめ」プラットフ...
    Masukawa_Nao Masukawa_Nao
    Naohiro Masukawa |
    Jan 21, 2025 4:00 PM
    199 views | 0 replies
  • 「工程のスクリーニング」の「シフトグラフ」で近年の気温上昇を検出する試み
    「工程のスクリーニング」は、多数の工程を一度に評価できるプラットフォームです。各工程における工程能力や管理図の指標を算出し、重要な工程を効率的にスクリーニングできます。   このプラットフォームでは、次のような「シフトグラフ」を描けるのはご存じでしょうか? このグラフにより、どの工程でいつシフト(後述)が発生したのかを視覚的に考察できます。また、気になる工程についてはドリルダウンで詳細に分析できます。 本ブログでは、日本各地の気温データを一種の「工程」とみなし、気温の急激な上昇(シフト)がいつ発生したか、また観測地点ごとの上昇幅の違いについて考察します。   分析対象 対象地域:日本の管区気象台および地方気象台(データが存在する58地点)対象期間:1995年~2024年(30年間)に対し、各年6月から8月(夏)のデータ指標:日ごとの平均気温、最高気温、最低気温について、3か月間の平均を算...
    Naohiro Masukawa |
    Jan 15, 2025 4:00 PM
    270 views | 0 replies
  • 3 ways to load your specification limits into Process Capability
    Process Capability
    tonya_mauldin tonya_mauldin
    JMPer Cable |
    Jan 14, 2025 9:21 PM
    24273 views | 1 replies
  • 從根本解決品質難題?解構製造業背後的品質控制秘密!
    深入解構製造業品質控制的挑戰與解決方案:從資料分析到製程優化,揭示如何利用數據分析工具解決製造業常遇到的品質管理與品質改善問題,提升產品穩定性與競爭力。
    JMP Blog |
    Jan 14, 2025 5:00 PM
    455 views | 0 replies
  • Disposable Income Change Remake
    Kaiser Fung recently critiqued this chart of changes in disposable income.He put forth the idea of using categorized slope graphs instead:How do we do something like that in JMP? We can do paneling and lines with variable color in Graph Builder; we just need to get the data into the right form. As usual, a key step in making a slope graph in Graph Builder is using Table > Stack to get the two data...
    XanGregg XanGregg
    The Plot Thickens |
    Jan 14, 2025 12:36 AM
    3107 views | 1 replies
  • JMP® Marketplace feature: Torch add-in
    The Torch Deep Learning add-in for JMP® Pro is a no-code interface to the PyTorch library for predictive modeling with deep neural networks. The add-in lets you train and deploy predictive models that use image, text, or tabular features as inputs to predict binary, continuous, or nominal targets.    A helpful feature of the add-in is its storybook, which offers example starting points for finding...
    russ_wolfinger russ_wolfinger
    JMP Blog |
    Jan 13, 2025 5:45 PM
    377 views | 0 replies
    No supplied image
