Collection of "funny" Jmp newbie questions
Level XII
good to know:
- how to do this and that in Jmp?
- where Jmp is different from other programs
- where Jmp is different from Jmp (inconsistencies)
[More Topic Containers like this]
Topicadditional info
Data Tables
Why is it not possible in Jmp:
- to define a formula for a specific cell?
- to select any 2 cells in a spreadsheet?
JMP is Not a Spreadsheet
Is there a tutorial how to "slice" matrices?
matrix[5::-1]
answer
NB: The indexing of matrices will be improved in a future version of Jmp
why new table()? answer
why is there no dt << n rows()?answer
Why does add row add a row to a data table - but doesn't add the values?answer
Why are there different column names for data imported via Open and MFI?answer
Is there something in JMP like freeze pane in Excel?
lock Columns
 Why do I need a numeric column to add a column with row numbers?
Graph Builder
Why do FitYbyX and GraphBuilder use different color codings?
answer
 When comes (collision free) Column Switcher 2.0?
wish:
Add new switcher called Role Switcher
GUI
Why is there no Select mode in the Local Data Filter - like the one from (global) Data Filter?wish:
Local Data Filter - don't disable the SELECT option
In the Join Tables Platform, what's the difference between
Update main table with data from second ta...
The submenus of my Jmp installation open to the left
- Where is the setting to move the submenus to t...
Why does Scripting Index/See also not list the function xyz ?you want more items to show up in see also ?
suggest them here:
Scripting Index and online Help: "see also"
Re: Collection of "funny" JSL newbie questions
39 REPLIES 39
Level XII
I just found infos like this one
https://www.jmp.com/support/help/en/16.2/?os=win&source=application#page/jmp/subscripts-2.shtml
with some basic indexing like
mat[from::to, from2::to2]
Is indexing also possible "relative to the end" (minus sign doesn't work) or indexing with open start or end (leaving the slot empty doesn't work)?
mat[1::-1];mat[1::];mat[::]
edit: wish
https://community.jmp.com/t5/JMP-Wish-List/new-slicing-options-for-matrices/idi-p/559090#M2563
Level XII
why is it
current data table()
data table("my name")
but
new table()
(without "data") - because there is no data yet in the table?
Here it seems that "tables" and "data tables" are something similar, but this is definitely not true:
https://community.jmp.com/t5/Discussions/Collection-of-quot-funny-quot-JSL-newbie-questions/m-p/5590...
Level XII
why are there so many messages that I can send to a data table but not
dt << n rows()
just working:
n rows (dt)
edit: wish
https://community.jmp.com/t5/JMP-Wish-List/lt-lt-n-rows-to-get-the-rows-of-a-data-table/idi-p/559101
Level XII
Why does add row add a row to a data table  - but doesn't add the values *)?
*) adding values with the same syntax  just works for Table Boxes
dt = New Table( "Untitled" );
dt << add row( {1} );
New Window( "test",
	tb = Table Box( String Col Box( "string col", {"a"} ),
	Number Col Box( "number col", {1} ) )
tb << add row( {"b", 2} );
edited: wish to provide a shortcut function like add row(list of values) also for data tables
(very convenient for data collection in for loops - e.g. for debugging)
https://community.jmp.com/t5/JMP-Wish-List/easy-way-to-add-rows-amp-values-to-a-data-table/idi-p/559...
The message
      Obj << Add Row( {values, .....} )
is a valid message for the Display Object, Table Box
The message
     Obj << Add Rows( ,n., ,At Start|At End|After(m)> | { list of ( column name = value ) pairs } ))
is a valid message to add rows to a data table.
Both messages allow for the adding of rows, but in different formats, since the objects are very different in functionality
Level XII
When I import a text file without header - why are the column names
and when I import the same file via "Import Multiple Files ...", they are
View more...
I assume it is because 2 different developers created the 2 different applications.
Level XII
another one:
(in JMP it just makes sense wrt. columns:
i.e. to have some index columns visible on the left, independent of the actual position in the table.)
Lock Columns (jmp.com) might work
