hogi
Level XIII
Collection of "funny" Jmp newbie questions
good to know:
- how to do this and that in Jmp?
- where Jmp is different from other programs
- where Jmp is different from Jmp (inconsistencies)
[More Topic Containers like this]
Topic additional info
Data Tables
Why is it not possible in Jmp:
- to define a formula for a specific cell?
- to select any 2 cells in a spreadsheet?
JMP is Not a Spreadsheet
Is there a tutorial how to "slice" matrices?
matrix[5::-1]
answer
NB: The indexing of matrices will be improved in a future version of Jmp
why new table()?  answer
why is there no dt << n rows()? answer
Why does add row add a row to a data table - but doesn't add the values? answer
Why are there different column names for data imported via Open and MFI? answer
Is there something in JMP like freeze pane in Excel?
lock Columns
 New Formula Column / Concatenate numeric values
New formula column / count strings
Graph Builder
Why do FitYbyX and GraphBuilder use different color codings?
answer
 When comes (collision free) Column Switcher 2.0?
wish:
Add new switcher called Role Switcher
GUI
Why is there no Select mode in the Local Data Filter - like the one from (global) Data Filter? wish:
Local Data Filter - don't disable the SELECT option
In the Join Tables Platform, what's the difference between
Update main table with data from second ta...
The submenus of my Jmp installation open to the left
- Where is the setting to move the submenus to t...
Why does Scripting Index/See also not list the function xyz ? you want more items to show up in see also ?
suggest them here:
Scripting Index and online Help: "see also"
43 REPLIES 43
Re: Collection of "funny" JSL newbie questions
I am not even sure that if the original developers of the syntax in question responded, that they would be able to say precisely why
new data table()
isn't the syntax to use.
Having worked my whole career with software systems developed by other people and organizations I find it is more productive to as "How do I do it", rather than "Why doesn't it do it this or that way".  The only real answer to the later question is "Because I wasn't the software developer, someone else was"
hogi
Level XIII
Yes, that's right, your posts live the spirit of "How do I do it" :)
I am always totally thrilled how you think out of the box and manage to get to the other side of a locked door, like such manually concatenated Strings plus a
parse( )
and that's it.
It's just that the need for "please read the Help and check the scripting index" would be less if the "easy doors" were all unlocked by default :)
Alternative approach:  detour signs in the scripting Index
https://community.jmp.com/t5/JMP-Wish-List/Scripting-Index-and-online-Help-quot-see-also-quot/idi-p/...
The inconsistencies in JMP are unfortunately a known issue.  The positive side is that when new releases come out, over time one sees that efforts are made to clean up the inconsistencies.  I strongly suggest that your observations be added to the JMP Wish List.  That way they get officially noted to those that can actually make changes.
It is a simple matter to slice matrices
names default to here(1);
mat = [10 20 30 40 50, 15 25 35 45 55];
show( mat[1,0]);
show( mat[1,2::4]);
mat[1,0] = [10 20 30 40 50];
mat[1,Index(2, 4)] = [20 30 40];
  • Is there a tutorial how to "slice" matrices?
    • What is the JSL Matrix?
    • Try using 0
    • Names Default To Here(1);
      m = J(2,5,1);
      Show(m[1,0]);
      Show(m[0,1]);
      Show(m[0,0]);
  • why are there so many messages that I can send to a data table but not
    • Data table object doesn't seem to have N Rows. N Rows is a different function which can be used on different objects
  • Why does add row add a row to a data table - but not the values?
    • Add Row does work (no idea why...) but you have to use different syntax when adding values (see Add Rows).
      dt = New Table( "Untitled" );
      dt << Add Row({"Column 1"n = 1});
      dt << Add Rows({"Column 1"n = 2});
hogi
Level XIII
Workaround for add row(with values):
collect the info in a Table Box, then use
and copy the data to a data table.
hogi
Level XIII
in the Scripting Index, there is a button "see also" which suggests the interested user alternative functions in the context of an initial found function.
Unfortunalely, there are some "links" missing between the entries. e.g.
get <-> set clipboard
N Args <-> Head
I posted a "container" wish to collect such missing links such that they can be added:
Did it happen to you as well that you search a function in the Scripting Index for some while and found out that you cannot find the right term to search it?
If you found the correct function afterwards by luck, could you please add a screenshot to the "container" wish to help other users to find the function faster ...
... and support the idea with a Kudo : )
hogi
Level XIII
ian_jmp
Level X
The 'Local Data Filter' applies to just the report from which you call it up, and a table may have multiple reports open at the same time. Allowing row selections this way could be confusing! On the other hand, there can only be one 'Data Filter' for a given table, and it affects all child reports of that table (so long as they don't have their own Local Data Filter).
hogi
Level XIII
Local data filter just has a local effect. I don't understand why the effect with 'select' was more confusing than the effect with 'include' enabled. Why confusing at all?
Local include determines which data is displayed in the current plot. Local select would determine which data is highlighted in the current plot.
Opposite to the general data filter, it's not the intention of a local data filter that anything in the underlying data table is selected / excluded :)
Hm, if "don't confuse the user" was indeed the argument why the option got disabled ...
then I would be happy if there was an option to re-enable the Select option (e.g. very hidden, by Shift Right-Click or so)
I mean: For those useful applications where the user will not be confused, but thrilled by the new possibilities :)
my wish:
