hogi
Level XIII
Collection of "funny" Jmp newbie questions
good to know:
- how to do this and that in Jmp?
- where Jmp is different from other programs
- where Jmp is different from Jmp (inconsistencies)
[More Topic Containers like this]
Topic additional info
Data Tables
Why is it not possible in Jmp:
- to define a formula for a specific cell?
- to select any 2 cells in a spreadsheet?
JMP is Not a Spreadsheet
Is there a tutorial how to "slice" matrices?
matrix[5::-1]
answer
NB: The indexing of matrices will be improved in a future version of Jmp
why new table()?  answer
why is there no dt << n rows()? answer
Why does add row add a row to a data table - but doesn't add the values? answer
Why are there different column names for data imported via Open and MFI? answer
Is there something in JMP like freeze pane in Excel?
lock Columns
 New Formula Column / Concatenate numeric values
New formula column / count strings
Graph Builder
Why do FitYbyX and GraphBuilder use different color codings?
answer
 When comes (collision free) Column Switcher 2.0?
wish:
Add new switcher called Role Switcher
GUI
Why is there no Select mode in the Local Data Filter - like the one from (global) Data Filter? wish:
Local Data Filter - don't disable the SELECT option
In the Join Tables Platform, what's the difference between
Update main table with data from second ta...
The submenus of my Jmp installation open to the left
- Where is the setting to move the submenus to t...
Why does Scripting Index/See also not list the function xyz ? you want more items to show up in see also ?
suggest them here:
Scripting Index and online Help: "see also"
43 REPLIES 43
hogi
Level XIII
Re: Collection of "funny" JSL newbie questions
hogi
Level XIII
hogi
Level XIII
Why is the data table object removed from Application Builder if I close the respective data table?
(leading to a non-functional Application)
edit: Hm, perhaps it's possible to change the behavior  - here is the wish
hogi
Level XIII
answer: Re: What-is-graph-builder's-color-ordering-different-than-other charts?
If this is an issue, it can be "fixed" by switching to Jmp Blue Red Green:
https://community.jmp.com/t5/JMPer-Cable/Graph-Builder-color-theme-add-in/bc-p/626423/highlight/true...
This is an example of one of the inconsistences in JSL.  Not all functions have a message equivalence.  I suggest that when you come across an inconsistency that you add a request to the JMP Wish List to resolve the inconsistancy
A function is a subroutine that you can call anywhere in a script. It might take one or more arguments. It returns a value. It might have a side effect, like instantiating a display box.
A message invokes a method implemented by an object.
It doesn't make sense (to me) to necessarily have a message to duplicate every function if that is what you are suggesting. What additional benefit does the message, dt << N Row, provide that you cannot get from the function call, N Row( dt )?
You must learn the syntax, keywords, functions, and protocols for any computer language.
hogi
Level XIII
@Mark_Bailey : Sure, there is no difference at all between N row(dt) and  the non-existing dt << n rows
... from the point of view of what you get.
But this post is about idioms of the jmp language which can make it hard for newbies to get what they want.
Sometimes, there are tiny "walls" or you get stuck in front of a locked door - this can be frustrating or irritating.
I could imagine that during the Trial Period some potential users of JMP got lost to other languages like Python or Matlab because of such difficulties.
The benefit of messages:
Let's imagine that a user has a data table dt and knows already that he can send messages like << get name to the object.
He also knows that typing
dt << get
and pressing CTRL+Space will help him to get possible candidates for what he wants.
And indeed, there is a << get rows() for data tables.
Unfortunately, this function does something else :(
Therefore, he keeps searching and searches the Scripting Index for other messages like Nitems, Length, Dimensions and so on.
Nothing - along the idea: If you don't know the correct function name, I cannot give you the correct info.
Then he just selects the data table object and scans all these messages, which can be sent to a data table. A huge list, but none of them does what the user wants. This takes a while ...
Another user uses the Scripting index and tries
then:
and scans the first 10 entries. Hm ...
(compare: https://www.google.com/search?q=length+data%20table+python)
As a next step, both  go to the JMP Community:
https://community.jmp.com/t5/forums/searchpage/tab/message?q=data%20table%20number%20rows
and find out that they were not the only ones who had this problem - what a relief!
And that's not all.
Fortunately, there are people who passionately help other users with their problems :)
From now on, both can tell other people that the function is not "length()", "dimensions()",  "len()", "size()" .... , but N row().
And that dt << N Rows() is not available because it would just be the same as N row(dt)
...  or N Rows(dt).
hogi
Level XIII
With Jmp18, there is now a Pythonista version of dt << n rows() :
I don't understand your
current data table()
data table("my name")
issue.
hogi
Level XIII
I edited the original text to make it clearer.
I wondered why it is not
new data table()
