multiple file import - even with slight differences
Hi,
I want to use the Import multiple files ..." to load csv files with slightly different structures: therer is huge overlap of columns, but some files have columns which the others don't.
In this case, the import seems to stop if a deviation is detected in a file.
my Wish: the program loads all files and there is a control to choose:
- just load columns that are available in all files
- load all data (and accept that there is no data for part of the files)
Thanks,
Holger
4 Comments
hogi
Level XIII
Ah, I just found out that this is already requested 2 years ago:
https://community.jmp.com/t5/JMP-Wish-List/Multiple-File-Import-Force-Combine/idi-p/255929
For sure, there is a workaround:
Let jmp generate several tables - one table for each variant of input files that it detects
- then concatenate the tables.
But it would be much easier to have just the 3rd option:
- I don't care about missing entries, just generate ONE file
besides
- stack similar files
- one table for each file
hogi
Level XIII
Status could be changed to duplicate
hogi
Level XIII
