%3CLINGO-SUB%20id%3D%22lingo-sub-461713%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3Emehrfacher%20Dateiimport%20-%20auch%20bei%20geringf%C3%BCgigen%20Unterschieden%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-461713%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EIch%20m%C3%B6chte%20mehrere%20Dateien%20importieren%20...%20verwenden%2C%20um%20CSV-Dateien%20mit%20leicht%20unterschiedlichen%20Strukturen%20zu%20laden%3A%20Es%20gibt%20eine%20gro%C3%9Fe%20%C3%9Cberlappung%20der%20Spalten%2C%20aber%20einige%20Dateien%20haben%20Spalten%2C%20die%20die%20anderen%20nicht%20haben.%3C%2FP%3E%3CP%3EIn%20diesem%20Fall%20scheint%20der%20Import%20anzuhalten%2C%20wenn%20eine%20Abweichung%20in%20einer%20Datei%20festgestellt%20wird.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3Emy%20Wish%3A%20Das%20Programm%20l%C3%A4dt%20alle%20Dateien%20und%20es%20gibt%20eine%20Steuerung%20zur%20Auswahl%3A%3C%2FP%3E%3CP%3E-%20Laden%20Sie%20einfach%20Spalten%2C%20die%20in%20allen%20Dateien%20verf%C3%BCgbar%20sind%3C%2FP%3E%3CP%3E-%20alle%20Daten%20laden%20(und%20akzeptieren%2C%20dass%20f%C3%BCr%20einen%20Teil%20der%20Dateien%20keine%20Daten%20vorhanden%20sind)%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EVielen%20Dank%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EHolger%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-461713%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EBenutzeroberfl%C3%A4che%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-472105%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EBetreff%3A%20Import%20mehrerer%20Dateien%20-%20auch%20bei%20geringf%C3%BCgigen%20Unterschieden%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-472105%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EAh%2C%20ich%20habe%20gerade%20herausgefunden%2C%20dass%20dies%20bereits%20vor%202%20Jahren%20angefordert%20wurde%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FMultiple-File-Import-Force-Combine%2Fidi-p%2F255929%22%20target%3D%22_blank%22%3E%20https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FMultiple-File-Import-Force-Combine%2Fidi-p%2F255929%3C%2FA%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EEs%20gibt%20sicher%20einen%20Workaround%3A%3C%2FP%3E%3CP%3ELassen%20Sie%20jmp%20mehrere%20Tabellen%20generieren%20%E2%80%93%20eine%20Tabelle%20f%C3%BCr%20jede%20Variante%20von%20Eingabedateien%2C%20die%20es%20erkennt%3C%2FP%3E%3CP%3E-%20dann%20die%20Tabellen%20verketten.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EAber%20es%20w%C3%A4re%20viel%20einfacher%2C%20nur%20die%203.%20Option%20zu%20haben%3A%3CBR%20%2F%3E%20-%20Ich%20k%C3%BCmmere%20mich%20nicht%20um%20fehlende%20Eintr%C3%A4ge%2C%20erzeuge%20einfach%20EINE%20Datei%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EAu%C3%9Ferdem%3C%2FP%3E%3CP%3E-%20%C3%A4hnliche%20Dateien%20stapeln%3C%2FP%3E%3CP%3E-%20eine%20Tabelle%20f%C3%BCr%20jede%20Datei%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-798065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EBetreff%3A%20Mehrere%20Dateien%20importieren%20%E2%80%93%20auch%20bei%20kleinen%20Unterschieden%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-798065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F42584%22%20target%3D%22_blank%22%3E%40Sarah-Sylvestre%3C%2FA%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-798418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EBetreff%3A%20Import%20mehrerer%20Dateien%20%E2%80%93%20auch%20mit%20geringf%C3%BCgigen%20Unterschieden%20%E2%80%93%20Status%20ge%C3%A4ndert%20in%3A%20Duplikat%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-798418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDuplikat%20von%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FMultiple-File-Import-Force-Combine%2Fidi-p%2F255929%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FMultiple-File-Import-Force-Combine%2Fidi-p%2F255929%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
multiple file import - even with slight differences
Hi,
I want to use the Import multiple files ..." to load csv files with slightly different structures: therer is huge overlap of columns, but some files have columns which the others don't.
In this case, the import seems to stop if a deviation is detected in a file.
my Wish: the program loads all files and there is a control to choose:
- just load columns that are available in all files
- load all data (and accept that there is no data for part of the files)
Thanks,
Holger
4 Comments
hogi
Level XIII
Ah, I just found out that this is already requested 2 years ago:
https://community.jmp.com/t5/JMP-Wish-List/Multiple-File-Import-Force-Combine/idi-p/255929
For sure, there is a workaround:
Let jmp generate several tables - one table for each variant of input files that it detects
- then concatenate the tables.
But it would be much easier to have just the 3rd option:
- I don't care about missing entries, just generate ONE file
besides
- stack similar files
- one table for each file
hogi
Level XIII
Status could be changed to duplicate
hogi
Level XIII
