%3CLINGO-SUB%20id%3D%22lingo-sub-461713%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3Eimportazione%20di%20pi%C3%B9%20file%2C%20anche%20con%20lievi%20differenze%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-461713%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ECiao%2C%3C%2FP%3E%3CP%3EVoglio%20usare%20Importa%20pi%C3%B9%20file%20...%22%20per%20caricare%20file%20csv%20con%20strutture%20leggermente%20diverse%3A%20c'%C3%A8%20un'enorme%20sovrapposizione%20di%20colonne%2C%20ma%20alcuni%20file%20hanno%20colonne%20che%20gli%20altri%20no.%3C%2FP%3E%3CP%3EIn%20questo%20caso%2C%20l'importazione%20sembra%20interrompersi%20se%20viene%20rilevata%20una%20deviazione%20in%20un%20file.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3Emy%20Wish%3A%20il%20programma%20carica%20tutti%20i%20file%20e%20c'%C3%A8%20un%20controllo%20per%20scegliere%3A%3C%2FP%3E%3CP%3E-%20basta%20caricare%20le%20colonne%20disponibili%20in%20tutti%20i%20file%3C%2FP%3E%3CP%3E-%20caricare%20tutti%20i%20dati%20(e%20accettare%20che%20non%20ci%20siano%20dati%20per%20parte%20dei%20file)%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EGrazie%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EHolger%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-461713%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EInterfaccia%20utente%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-472105%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERi%3A%20importazione%20di%20pi%C3%B9%20file%2C%20anche%20con%20lievi%20differenze%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-472105%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EAh%2C%20ho%20appena%20scoperto%20che%20questo%20%C3%A8%20gi%C3%A0%20richiesto%202%20anni%20fa%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FMultiple-File-Import-Force-Combine%2Fidi-p%2F255929%22%20target%3D%22_blank%22%3E%20https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FMultiple-File-Import-Force-Combine%2Fidi-p%2F255929%3C%2FA%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EDi%20sicuro%2C%20c'%C3%A8%20una%20soluzione%20alternativa%3A%3C%2FP%3E%3CP%3ELascia%20che%20jmp%20generi%20diverse%20tabelle%3A%20una%20tabella%20per%20ogni%20variante%20di%20file%20di%20input%20che%20rileva%3C%2FP%3E%3CP%3E-%20quindi%20concatenare%20le%20tabelle.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EMa%20sarebbe%20molto%20pi%C3%B9%20semplice%20avere%20solo%20la%20terza%20opzione%3A%3CBR%20%2F%3E%20-%20Non%20mi%20interessano%20le%20voci%20mancanti%2C%20genera%20solo%20UN%20file%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3Eoltretutto%3C%2FP%3E%3CP%3E-%20impilare%20file%20simili%3C%2FP%3E%3CP%3E-%20una%20tabella%20per%20ogni%20file%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-798065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20importazione%20di%20pi%C3%B9%20file%20-%20anche%20con%20piccole%20differenze%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-798065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F42584%22%20target%3D%22_blank%22%3E%40Sarah%20Sylvestre%3C%2FA%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-798418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20importazione%20di%20pi%C3%B9%20file%20-%20anche%20con%20piccole%20differenze%20-%20Stato%20modificato%20in%3A%20Duplicato%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-798418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDuplicato%20di%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FMultiple-File-Import-Force-Combine%2Fidi-p%2F255929%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FMultiple-File-Import-Force-Combine%2Fidi-p%2F255929%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
multiple file import - even with slight differences
Hi,
I want to use the Import multiple files ..." to load csv files with slightly different structures: therer is huge overlap of columns, but some files have columns which the others don't.
In this case, the import seems to stop if a deviation is detected in a file.
my Wish: the program loads all files and there is a control to choose:
- just load columns that are available in all files
- load all data (and accept that there is no data for part of the files)
Thanks,
Holger
4 Comments
hogi
Level XIII
Ah, I just found out that this is already requested 2 years ago:
https://community.jmp.com/t5/JMP-Wish-List/Multiple-File-Import-Force-Combine/idi-p/255929
For sure, there is a workaround:
Let jmp generate several tables - one table for each variant of input files that it detects
- then concatenate the tables.
But it would be much easier to have just the 3rd option:
- I don't care about missing entries, just generate ONE file
besides
- stack similar files
- one table for each file
hogi
Level XIII
Status could be changed to duplicate
hogi
Level XIII
