%3CLINGO-SUB%20id%3D%22lingo-sub-461713%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3Eimportation%20de%20plusieurs%20fichiers%20-%20m%C3%AAme%20avec%20de%20l%C3%A9g%C3%A8res%20diff%C3%A9rences%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-461713%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ESalut%2C%3C%2FP%3E%3CP%3EJe%20souhaite%20utiliser%20Importer%20plusieurs%20fichiers%20...%22%20pour%20charger%20des%20fichiers%20csv%20avec%20des%20structures%20l%C3%A9g%C3%A8rement%20diff%C3%A9rentes%26nbsp%3B%3A%20il%20y%20a%20un%20%C3%A9norme%20chevauchement%20de%20colonnes%2C%20mais%20certains%20fichiers%20ont%20des%20colonnes%20que%20les%20autres%20n'ont%20pas.%3C%2FP%3E%3CP%3EDans%20ce%20cas%2C%20l'import%20semble%20s'arr%C3%AAter%20si%20un%20%C3%A9cart%20est%20d%C3%A9tect%C3%A9%20dans%20un%20fichier.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3Emy%20Wish%20%3A%20le%20programme%20charge%20tous%20les%20fichiers%20et%20il%20y%20a%20un%20contr%C3%B4le%20%C3%A0%20choisir%20%3A%3C%2FP%3E%3CP%3E-%20chargez%20simplement%20les%20colonnes%20qui%20sont%20disponibles%20dans%20tous%20les%20fichiers%3C%2FP%3E%3CP%3E-%20charger%20toutes%20les%20donn%C3%A9es%20(et%20accepter%20qu'il%20n'y%20ait%20pas%20de%20donn%C3%A9es%20pour%20une%20partie%20des%20fichiers)%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EMerci%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EHolger%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-461713%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EInterface%20utilisateur%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-472105%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%26nbsp%3B%3A%20importation%20de%20fichiers%20multiples%20-%20m%C3%AAme%20avec%20de%20l%C3%A9g%C3%A8res%20diff%C3%A9rences%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-472105%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EAh%2C%20je%20viens%20de%20d%C3%A9couvrir%20que%20c'est%20d%C3%A9j%C3%A0%20demand%C3%A9%20il%20y%20a%202%20ans%20%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FMultiple-File-Import-Force-Combine%2Fidi-p%2F255929%22%20target%3D%22_blank%22%3E%20https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FMultiple-File-Import-Force-Combine%2Fidi-p%2F255929%3C%2FA%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EBien%20s%C3%BBr%2C%20il%20existe%20une%20solution%20de%20contournement%26nbsp%3B%3A%3C%2FP%3E%3CP%3ELaissez%20jmp%20g%C3%A9n%C3%A9rer%20plusieurs%20tables%20-%20une%20table%20pour%20chaque%20variante%20de%20fichiers%20d'entr%C3%A9e%20qu'il%20d%C3%A9tecte%3C%2FP%3E%3CP%3E-%20puis%20concat%C3%A9ner%20les%20tables.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EMais%20il%20serait%20bien%20plus%20simple%20de%20n'avoir%20que%20la%203%C3%A8me%20option%20%3A%3CBR%20%2F%3E%20-%20Je%20me%20fiche%20des%20entr%C3%A9es%20manquantes%2C%20g%C3%A9n%C3%A9rez%20juste%20UN%20fichier%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3Eoutre%3C%2FP%3E%3CP%3E-%20empiler%20des%20fichiers%20similaires%3C%2FP%3E%3CP%3E-%20un%20tableau%20pour%20chaque%20dossier%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-798065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20importation%20de%20fichiers%20multiples%20-%20m%C3%AAme%20avec%20de%20l%C3%A9g%C3%A8res%20diff%C3%A9rences%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-798065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F42584%22%20target%3D%22_blank%22%3E%40Sarah-Sylvestre%3C%2FA%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-798418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20importation%20de%20fichiers%20multiples%20-%20m%C3%AAme%20avec%20de%20l%C3%A9g%C3%A8res%20diff%C3%A9rences%20-%20Statut%20modifi%C3%A9%20en%20%3A%20Dupliqu%C3%A9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-798418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDuplicata%20de%20%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FMultiple-File-Import-Force-Combine%2Fidi-p%2F255929%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FMultiple-File-Import-Force-Combine%2Fidi-p%2F255929%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
multiple file import - even with slight differences
Hi,
I want to use the Import multiple files ..." to load csv files with slightly different structures: therer is huge overlap of columns, but some files have columns which the others don't.
In this case, the import seems to stop if a deviation is detected in a file.
my Wish: the program loads all files and there is a control to choose:
- just load columns that are available in all files
- load all data (and accept that there is no data for part of the files)
Thanks,
Holger
4 Comments
hogi
Level XIII
Ah, I just found out that this is already requested 2 years ago:
https://community.jmp.com/t5/JMP-Wish-List/Multiple-File-Import-Force-Combine/idi-p/255929
For sure, there is a workaround:
Let jmp generate several tables - one table for each variant of input files that it detects
- then concatenate the tables.
But it would be much easier to have just the 3rd option:
- I don't care about missing entries, just generate ONE file
besides
- stack similar files
- one table for each file
hogi
Level XIII
Status could be changed to duplicate
hogi
Level XIII
