  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
multiple file import - even with slight differences
Hi,
I want to use the Import multiple files ..." to load csv files with slightly different structures: therer is huge overlap of columns, but some files have columns which the others don't.
In this case, the import seems to stop if a deviation is detected in a file.
my Wish: the program loads all files and there is a control to choose:
- just load columns that are available in all files
- load all data (and accept that there is no data for part of the files)
Thanks,
Holger
4 Comments
hogi
Level XIII
Ah, I just found out that this is already requested 2 years ago:
https://community.jmp.com/t5/JMP-Wish-List/Multiple-File-Import-Force-Combine/idi-p/255929
For sure, there is a workaround:
Let jmp generate several tables - one table for each variant of input files that it detects
- then concatenate the tables.
But it would be much easier to have just the 3rd option:
- I don't care about missing entries, just generate ONE file
besides
- stack similar files
- one table for each file
hogi
Level XIII
Status could be changed to duplicate
hogi
Level XIII
Sarah-Sylvestre
Level V
