%3CLINGO-SUB%20id%3D%22lingo-sub-461713%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3Eimportaci%C3%B3n%20de%20archivos%20m%C3%BAltiples%2C%20incluso%20con%20ligeras%20diferencias%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-461713%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EHola%2C%3C%2FP%3E%3CP%3EQuiero%20usar%20Importar%20archivos%20m%C3%BAltiples...%22%20para%20cargar%20archivos%20csv%20con%20estructuras%20ligeramente%20diferentes%3A%20hay%20una%20gran%20superposici%C3%B3n%20de%20columnas%2C%20pero%20algunos%20archivos%20tienen%20columnas%20que%20otros%20no.%3C%2FP%3E%3CP%3EEn%20este%20caso%2C%20la%20importaci%C3%B3n%20parece%20detenerse%20si%20se%20detecta%20una%20desviaci%C3%B3n%20en%20un%20archivo.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3Emy%20Wish%3A%20el%20programa%20carga%20todos%20los%20archivos%20y%20hay%20un%20control%20para%20elegir%3A%3C%2FP%3E%3CP%3E-%20simplemente%20cargue%20las%20columnas%20que%20est%C3%A1n%20disponibles%20en%20todos%20los%20archivos%3C%2FP%3E%3CP%3E-%20cargar%20todos%20los%20datos%20(y%20aceptar%20que%20no%20hay%20datos%20para%20parte%20de%20los%20archivos)%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EGracias%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EHolger%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-461713%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EInterfaz%20de%20usuario%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-798065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20importaci%C3%B3n%20de%20varios%20archivos%2C%20incluso%20con%20ligeras%20diferencias%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-798065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F42584%22%20target%3D%22_blank%22%3E%40Sarah-Sylvestre%3C%2FA%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-798418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20importaci%C3%B3n%20de%20varios%20archivos%20(incluso%20con%20ligeras%20diferencias)%20-%20Estado%20cambiado%20a%3A%20Duplicado%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-798418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDuplicado%20de%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FMultiple-File-Import-Force-Combine%2Fidi-p%2F255929%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FMultiple-File-Import-Force-Combine%2Fidi-p%2F255929%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
multiple file import - even with slight differences
Hi,
I want to use the Import multiple files ..." to load csv files with slightly different structures: therer is huge overlap of columns, but some files have columns which the others don't.
In this case, the import seems to stop if a deviation is detected in a file.
my Wish: the program loads all files and there is a control to choose:
- just load columns that are available in all files
- load all data (and accept that there is no data for part of the files)
Thanks,
Holger
4 Comments
hogi
Level XIII
Ah, I just found out that this is already requested 2 years ago:
https://community.jmp.com/t5/JMP-Wish-List/Multiple-File-Import-Force-Combine/idi-p/255929
For sure, there is a workaround:
Let jmp generate several tables - one table for each variant of input files that it detects
- then concatenate the tables.
But it would be much easier to have just the 3rd option:
- I don't care about missing entries, just generate ONE file
besides
- stack similar files
- one table for each file
hogi
Level XIII
Status could be changed to duplicate
hogi
Level XIII
