Ray Marching and WebP
This post shows a way-too-slow way to do ray marching and a perfectly fine Python way to make an animated WebP (like an animated Gif, but so much nicer!) Part 1: file formats This JSL uses the Python PIL library to make some test files to compare size, speed, and quality of PNG, JPEG, and WebP files. GIF is in part 2. If you want to run it, use 0 or 1 on the second line to make each picture. Th...
