BookmarkSubscribe
miomio
Community Trekker
prediction - and confidence interval for selected levels?
Hello!
I know how to do a "general" prediction - and confidence interval in JMP. However, I don't have any idea how to do it for selected levels - for example, if I only want to do a prediction - and confidence interval for the educational levels of 9, 12, 15 and 17 as in this example that I have attached.
How do I do the example I have attached in JMP?
// MIO
wilkap
Community Trekker
Re: prediction - and confidence interval for selected levels?
If I understand your question, you have created a predictive model using JMP and you want to use it in a table to show Confidence Limits on the mean and on individuals for specific instances only.
If that is correct, you can save the formulas for predicting individual and mean Confidence Limits, from the Hot Spot menu, to your original table.  You can copy and paste these into a new table with the data you are interested in.  Just be sure all the names are the same.
For example:
Create this new table.
Make sure all of the column names are the same.  You can copy all the formulas at once using "Copy Multi Columns Properties" and paste
them using "Paste Multi Columns Properties."
I hope this helps.
lconley20
Community Trekker
Is there a way to generate the same type table for a prediction interval limits?
lconley20
Community Trekker
I just realized individual confidence interval is the same as the prediction interval
