How do I copy and paste a formula
I am using
I am trying to paste the following formula from one data table to another (similar) table:
However when I paste it into the new table I get an error message and the formula will not work
How do I resolve this so that the formula will operate properly?  Thanks
11 REPLIES 11
hogi
Level XIII
Re: How do I copy and paste a formula
issues and explanations:
    you tried to paste the formula into column "Day". this leads to a loop day = f(day) - and the evaluation is interrupted.
    you renamed the input column day -> "Day of week"
    no column "day" -> formula complains
  • Character vs. Number issue.
    your original formula need "day" as Character, but in the new table "day" is a number
    --> open the column properties and change the data type from numeric to character
hogi
Level XIII
But as "Day" is numeric in your new table, the easiest solution is:
right click on the column header and go to New Formula Column / Date Time / Day of Week Name
Then Jmp will generate a new column Day of Week[Day]
