BookmarkSubscribeRSS Feed
Using a variable as an X value in paired t-test.
So I have the following code:
col = ":Sex";
New Window("AQP8 Normal",
Matched Pairs(
X(:Name("col")),
Y( :Name( "AQP8-Norm-Memb" ), :Name( "AQP8-Norm-Cyto" ) ),
Reference Frame( 1 ),
Wilcoxon Signed Rank( 1 )
It doesn't work. No error messages, no nothing. Very annoying.
Any ideas on how I can use a variable to assign X?
Thanks.
Related rant feel free to ignore: WHY DIDN'T SAS JUST USE C/C++ AS THE BASE OF THE LANGUAGE INSTEAD OF COMING UP WITH SOME "NEW" LANGUAGE!! PISSES ME OFF IN SAS TOO!
Thanks. I'm done. I feel better now. :)
ms
Jun 23, 2011
Re: Using a variable as an X value in paired t-test.
Have you checked the log for error messages? Usually you will get a hint in the log of what's causing the script to fail.
In your script I found two potential errors: The col assignment (you assign a string ":Sex" to col instead of a column) and the X assignment (you assign a column with heading col rather than use the column variable col)
This should work:
That is indeed the solution.
Thanks for your help.
