lukasz
How to extract only values (number or text) from a data table?
Hello Everybody,
After returning certain values from a data table I want to display them in a text edit box. However, I am getting values together with brackets [ ] for numbers and {" "} for characters. How to extract only content without additional brackets (and quotation marks)? Best regards.
Re: How to extract only values (number or text) from a data table?
You need to read the Scripting Guide.  What you are getting back are JMP Lists {} and JMP Matrices [].  You can deal with them by using subscripting, as in an array.
If what you received back is
    myList = { "Red", "Green" };
you can refer to which ever value by the appropriate subscript
     myList[2]
would return
     "Green"
lukasz
Of course, thank you. And yes, I will read the scripting guide. Best regards
