BookmarkSubscribe
How do I call a script from a script?
I would like to have one high level script which calls several others. I have been searching the manual for some time and can't figure out how to do this.
If I have scripts in a folder called a.jsl, b.jsl etc.
How command do I use in a script (such as master.jsl) to execute these in sequence?
Re: How do I call a script from a script?
The command you are looking for is Include("pathname"). This command parses a script then executes it. You can look at the documentation on page 102 in the Scripting Guide. Hope this helps.
