Level XII
CTRL/Alt/Shift + click/select/double click/right click
In JMP there are thousands of hidden eastereggs.
Here is an overview of many tricks -  what you will get when you CTRL/Alt/Shift + click/select/double click/right click.
[More Topic Containers like this]
General
 Select a range of adjacent items:
rows, columns, legend entries ...
Press Shift and click the first and last item
sometimes: click and drag.
 Select or deselect non-adjacent itemsPress Ctrl and click each item
 Paste a list of column names from the clipboard
into a dialog column list box (e.g. X,factor)
Graphs / Graph Builder
 use a column for the graphdrag it into the plot area
or: drag it into a dropzone
 use 2 columns in a common subplotdrag them onto the X or Y axis
or: drag the second column almost into the same dropzone (the dropzone with direction towards the graph)
 create a hierarchy on the X or X axisdrag an additional column almost into the same dropzone (the dropzone further away from the graph)
 create a hierarchy in the Group X or X regiondrag an additional column into the corner of the Group X/Y DropZone
 sort an axis by a second columndrag the second column almost into the same dropzone (the dropzone furthest  away from the graph)
 use 2 columns in separate subplots
drag them onto the X or Y axis (while pressing Shift)
or: drag the second column onto the the same axis, next to the first region
 use 2 columns as color
drag both columns into the color drop zone
or: drag the second column into the corner of the Color dropzone
a)Select points in a rectangular region.Click and drag the arrow tool.
b)Select points in a non-rectangular region.use the lasso tool
     extend the selectionpress Shift and select.
     remove data points from the (partial) selection press SHIFT + CTRL and select
    toggle data points
    (selected ones get unselected,
    unselected ones get selected)
press CTRL / ⌘ and select
c)
select points via the legend
click on an entry in the legend
press CTRL / ⌘ and click (2x will trigger selection)
or press Shift + CTRL / ⌘ and click (2x won't have an effect)
(eventually twice -  first to deselect (partial selection))
    toggle data points
d)
select points in an interactive HTML
press shift and/or CTRL / ⌘ and click
(eventually twice - first to deselect (partical selection))
 Change axis settings.Double-click or press Alt and click the axis.
 Add a reference lineDouble-click the axis at the desired position - the corresponding value will show up in the axis/reference line menu. hogi_6-1673821286969.png
 Change axis range
click and drag and axis
along the axis to move the center
perpendicular to the axis to change the range
Press Shift to prevent Jmp from changing the Ticks settings
 Change the binning of a Histogram Plot
Use the grabber tool: hogi_0-1708459924071.png, select one bar of the histogram and drag it up/down (# bins) left/right (offset)
 Reset the zoom to the original *) plot
*) either defined by the script or last state before using the magnifier the first time
double click into the graph (alternatively: Alt + click)
(with magnifier tool)
 change the color/marker etc. settings of a specific legend entryhover over the legend entry, right click and change the setting
 change the color/marker etc. settings of all legend entries referring to the same rows (lines and markers at the same time)select on of the legend entries by clicking, right click and change the setting
 clear label selection
click on one of the selected items
 - Show excluded data points / categories.
Press Shift, click the red triangle icon, and click on Show Excluded Rows
 change the type of summary statistics
Right-click on the caption box, click summary statistics and change the type.
CTRL / ⌘Right-click to change the type in all subplots simultaneously
 Let a 3D Scatterplot spinPress Shift and drag it with the mousehogi_0-1675539074444.png
 scale subplots individuallyresize the label (go from the label to the side, till the mouse changes to an arrow) - not the framebox!hogi_0-1677956288517.png
 Change/sort X Group labelsRight click - Configure Levels ...
 synchronize parallel axesShift click red triangle / Parallel Axis Merginghogi_0-1687500769810.png
 add an additional plot theme to the PlotShift click into another plot theme icon on the top
 add/remove plot themes to/from individual subplotsCtrl click into the upper/center/lower left/center/right region of the respective plot theme icon corresponding to the location of the subplot
 change tick labelsclick on a tick label and hold the mouse button for a while, edit the label and press ESChogi_0-1683409638302.png
 pin Crosshairright click - then (left) click on the window titlehogi_12-1673821931849.png
Profiler
 change factor settingsAlt + click into one of the profiler graphs
Reports
 apply a Platform Preset to a new report
[JMP 18] drag the Platform Preset symbol from the source report onto the target report
 get a hover explanation.
draw a small circle with your mouse
 remove the Header Bar of the OutlineBox
delete the title of the OutlineBox
 access the red triangle menu without a red triangle
Even when the outline is hidden, there is a tiny hotspot for the red triangle menu in the upper left.
 add columns to Distribution Platform
Drag the columns from the columns menu of the table
 Turn numeric report output into a data table.
Right-click somewhere in the report and select
Make into Data Table.
for Reports with BY:
Make combined Data Table.
 broadcast a command to all similar reports in the current window.
Press Ctrl / ⌘ and apply the command to one of the reports. e.g.
- click on the red triangle icon, and then select the command
- right click into a graph and apply a command
 collapse similar outline boxesPress Ctrl / ⌘, and click on the grey triangle hogi_0-1683408961708.png
 Select multiple report options.Press Alt (^ and Option) and right-click a disclosure iconhogi_0-1668785813247.png
 Select multiple analysis optionsPress Alt / Option and click a red triangle iconhogi_1-1668785851799.png
 Resize all similar graphs in a report.Press Ctrl/ ⌘ and resize one graph.
 change the formal of an entrydouble click the entryhogi_12-1673821931849.png
 Select multiple bars in a Distribution/Pareto  plot.Press Shift or Ctrl/ ⌘ and click the bars.
(differs from the "typical" explorer-like behavior:
(Ctrl/ ⌘ to select inividual entries
Shift to select all entries in between)
which is used for row, legend entries, ...)
 Deselect multiple bars in a Distribution/Pareto plot.Press Ctrl and click the bars.
 Create a subset of the data table from a histogram/Pareto Plot.
Double-click /
Press Shift,select the bars that you want to subset, and then double-click /
Select one or more bars, right-click, and then select Subset.
 Change the scale of a slider in the Contour Profiler.Right-click the slider.
(mac: Press ^ and click the slider.)
 Specify or lock a factor value in the Prediction Profiler.Press Alt and click inside one of a factor’s panes.
 Transpose the factors in a two-factor interaction LS Means plot.Press Shift and select the LS Means Plot command.
 Specify the alpha level when saving mean or individual confidence intervals.Press Shift, click the red triangle icon, and then select the command.hogi_11-1673821809907.png
 Specify theta (for exponential), beta (for Weibull), or sigma (for lognormal) parameters for WeiBayes analysis.Press Shift and select Exponential, Weibull, or Lognormal Fit from the Product-Limit Survival Fit red triangle menu.
 Lock a factor (in a profiler)Press Alt and click into the respective plot, then select Lock Factor Settinghogi_4-1673821177582.png
 Show Tree Structure of a ReportCtrl+Shift+Right Click the top left cornerhogi_0-1683408961708.png
Tables
 change property of multiple columns in columns managerselect multiple columns and press CTRL when changing the setting (will prevent JMP from resetting the selection)hogi_4-1673821177582.png
 Jump to a columnDouble-Click the column in the menu on the left.hogi_14-1673822201795.png
 keep a column visable all the timeSelect a column, click Col Menu/Scroll Lock
 Deselect rows and columns.Click the top triangular region in the upper left corner of the data grid to deselect columns. Click the bottom triangular region to deselect rows.hogi_20-1673822704702.png
 add columns/rowsdouble-click the top/bottom triangular menu in the upper left corner
 add a single column at the end of the tabledouble-click in the table right to the last columnhogi_0-1673944863249.png
 enter a new column nameclick on the column name on the top of the table and start typinghogi_16-1673822278724.png
 Copy a list of column names to the clipboardSelect the columns in the column list on the left
of the data table and press CTRL/ ⌘ + C
 change several column names at once
copy the column names to the clipboard
select the columns in the menu on the left, paste the new names
 fill all cell of a column with the same valueselect the column header - no row selection - Ctrl/ ⌘ + V
NOT:  overwrite the column name (!)
 Repeat values or a sequence of values in a column.Right-click on selected cells. Select Fill and the appropriate command.
 Fill empty values with previous entries of that column.
select a column and some rows,
Right-click on an entry and press Replace missing
 Generate a subset of the current selection right click on Selected and click on  Data Viewhogi_5-1673821208525.png
 move column(s) to another position in the data tableselect the column(s) (on top of the table or in the columns list on the left), keep the mouse button pressed and drag the column(s) to the new position
 Merge column(s) from a summary table into the main tableselect the column(s) (on top of the summary table ).
Click again, keep the mouse button pressed and drag the column(s) to the main table.
 Edit a Table ScriptDouble-Click the script
 copy a column scriptRight-Click on the column header and click on Copy Columns
 copy a column script - including the values select all rows,  Right-Click on the column header and click on Copy Columns
 copy a column script - including the values of N specific rows select the rows,  Right-Click on the column header and click on Copy Columns
(strange:values will be applied to the first N rows)
 define multiple value labels at oncecopy value & label pairs from a table, point at the field with value-label pairs and paste (instead of entering them one by one)hogi_14-1673822201795.png
 adjust the column width to the content[JMP 18] double click the separator linehogi_0-1673944863249.png
JSL Editor
 Select a non-rectangular block of textClick and drag the cursor.
 Select a rectangular block of textPress Alt and drag the cursor over the text.
 Select multiple rectangular blocks of textPress Ctrl and drag the cursor over a non-rectangular block of text. Move the cursor to a new location and repeat.
Copying, cutting collects the text in the order in which each block was selected.
 type synchronously at multiple positions in the textPress Ctrl and click on multiple positions,
then start typing.
 Open JSL command in Scripting IndexPress Alt and double-click on a command
 Run a script with a specific data tablecopy the script and paste it into the table script menu
 Select the code between bracketsDoble-click one of the brackets
 ... marke the command in front as well... press Shift and click on the first letter of the command
    or: press CTRL + Shift + arrow left (N times)
 copy a line of codeplace the cursor into the line ( no need to select anything)  and press CTRL/ ⌘ + Chogi_0-1673914495379.png
Formula Editor
 Terminate running code
Press
Esc
 Build Match function
conditionals
Select a column from Table Columns list.
Press Shift and select Match from Conditional formula list.
 replace something in the formula with something elseselect the item to replace (-> blue rectangle)
Double-click the new item (column, constant, variable, parameter)
 Swap two expressions in a formula.Drag one expression on top of the other expression.hogi_0-1673820949434.png
Column List Box
 Add a column to the listdrag the column into the list
 Remove column from a list
(Platform menu, Column Switcher etc.)
Data Filter
 Add a filterdouble click on the column
 Add multiple filters at onceselect multiple columns and click hogi_1-1668790185822.png
 numeric data filter: change the upper/lower limit
drag the fence,
click onto the number and enter a new value
 numeric data filter: move the range
click the shaded pass region and move it to the new location
Re: CTRL/Alt/Shift + click/select/double click/right click
Quick Reference Card is one place where you can find some of those. Quick Reference Card can be accessed from JMP's help menu
Level XII
Thanks  @jthi
Starting with these 9 pages, let's see how far we can get collecting also the easter eggs from the better hidden places ...
I will collect all posts in one table.
edit: table moved to the 1st post
P_Bartell
Level VIII
During my tenure as a Senior JMP Systems Engineer I told my JMP/JMP Pro customers, "When in doubt, move the cursor/I beam over the thing you are most interested in, and right click. Chances are good this will uncover a pathway to do whatever it is you are trying to do." Or as my colleague @gail_massari was fond of saying, "Right click is your friend."
@hogi, Thank you for adding information about selection in Interactive HTML (and JMP Live).
More information on how to interact with Interactive HTML content can also be found here:
https://www.jmp.com/support/help/InteractiveHTML/17/ShareJMPReports.shtml
Thanks,
~John
Level XII
Thanks @John_Powell_JMP for the link.
I added an easter egg link.
Level XII
nice plenary talk by @John_Sall on Secret Features of JMP .
jschroedl
With the release of JMP 18 imminent, I'll add one from there. Have you ever opened a data table with the column titles wrapped or cut off just a bit making them hard to read?  In JMP 18, select the affected columns and double-click on one of the divider lines between column headers to have JMP auto-size the columns making them more readable. This can also be done in the menus using Cols > Reset Display Width.  If there's just a single column to fix up, double-click the right edge of its title box and it'll reset the width.
