JMP Wish List
Restore Edit a table script with double-click, Paste a table script with Ctrl+v
What inspired this wish list request? the functionality to Edit a table script with double-click, and Paste a table script with Ctrl+v was removed in JMP 19.
What is the improvement you would like to see? Put it back the way it was
Why is this idea important? This is core functionality that has been part of my workflow for many years. The new workflow is cumbersome and keeps me from focusing on what I'm working on to spend unnecessary time trying to figure out how to do what was once second nature.
4 Comments
Level XIII
really annoying!
Users use this functionality for decades - and then it gets deleted!
now, with a double click the NAME of the script can be edited.
In JMP18, one can select a script and then click again to edit the name.
This is no longer possible.
  1. Please change back the functionality of the Double click!
  2. Please activate again the funtionality to edit the script name via "select and click again"
Level XIII
Edit table script via double click:
I just contacted JMP support : TS-00247180
Was the function removed unintentionally while restructuring the Data Pane?
i.e. : any chance to get it back?
Or was it removed intentionally - without a chance to get it back?
->they don't know. The suggestion: Use the Wish List to communicate with the Development team.
Interesting ... So:
@DavidWhite ,
The new Data Pane is amazing!!!
Column Tags, Filter views, interactivity between column menu and data pane, ....
With all the great improvements - was "edit table script by double click" removed unintentionally ?
any chance to get it back in JMP19.1?
Another issue: it's just possible to open the script "once ".
In JMP<=18,  a second double click brought the open window to the front.
In JMP19, if the script is open, there is no shortcut anymore to bring the script to the front, just a grey command  "Edit with recode..."  (?!?)
Sarah-Sylvestre
Thank you for submitting this request!
Level XIII
@Sarah-Sylvestre , paste Table Script is back with v 19.1.
Edit Table Script via Double Click is still not possible.
Is another shortcut added?
