agonzales2021
How to Hide Outline Box of Graph Builder
I would like to Hide the outline box that surrounds a graph builder.
I tried making it a report and deleting the Outline Box like
ybuild = Graph Builder();
yrep = ybuild << report;
yrep[ OutlineBox(1) ] << Delete;
The entire report just disappears.
13 REPLIES 13
Level XIII
Re: How to Hide Outline Box of Graph Builder
If I want to access the red triangle menu after hiding the OutlineBox, e.g. to access the red triangle menu
... is
report(gb)[ OutlineBox(1) ] << Set Title("show");
the only way?
I hope there is an alternative solution
XanGregg
Even when the outline is hidden, there is a tiny hotspot for the red triangle menu in the upper left. You will see the cursor change to a pointing hand icon when you're over it.
Level XIII
Wow, nice!
Thanks, @XanGregg for the info.
added to CTRL/Alt/Shift + click/select/double click/right click :)
Level XIII
@John_Sall  @~ 9min:
If you Click on that little red triangle, you get a menu of commands, okay?
One of the secrets is you can right Click anywhere else in that report and get that same menu
really! I was excited - no need to find the tiny Red-Triangle memorial hotspot?
but as it seems, the alternative option to right Click anywhere else is just available as long as the red triangle is available ...
