Level XIII
Actions missed by Advanced Log/Workflow Builder
container to collect actions which are not recorded yet.
NB:
"Workflow Builder + Add-Ins"  is already discussed in this post:
and this wish list entry:
Workflow Builder + AddIns
[More Topic Containers like this]
NB: If an action gets recorded by new version of Jmp, I  try to update the posts.
@ Jmp support, development: If I missed to do so, feel free to change the respective post (I guess you can do so)
      fixed: last checked
1 delete cell values Link - 19.0.3
2 fill to end of table / fill to row Link 17.2
2b replace missing with previous values new bug 19.0.?
3 enable scroll lock Link - 19.0.3
4 run table script Link - 19.0.4
5
12
manual row and column selection
row selection via "select rows"
Link
Link
19.0.3
6 summary: drag n drop Link  - 19.0.3
7 row colors & markers Link 17.2
8 Tables/summary: LDF Link 17.1
9 open html file Link - 19.0.3
10 open H5 file Link -
11 copy frame content Link - 19.0.3
13 clear exclude / hide Link - 19.0.3
14 Virtual Links: settings Link - 19.0.3
16 optimize: row deletion after selection via header graph Link 17.2
17 copy to journal Link - 19.0.3
17a
17? - again - sorry
outline close orientation
Link 18.?
17b display box orientation   - 19.0.3
18 actions from tables red triangle menu Link - 19.0.3
19 width=0 Link -
20 initial column values Link
21 save project Link
37 REPLIES 37
Re: Actions missed by Advanded Log/Worflow Builder
Mentioning @Mandy_Chambers, as she mentioned in Discovery last year that she wanted to be in the loop from anything not being recorded.
thanks @Jed_Campbell I think as i read through this, Julian had answered most everything.  Mostly that you can't record the add-ins with workflows -- and that some actions could not be scripted to the workflow either.  If there is something else here specifically that needs a note, let me know  I'd be happy to add another ticket.  it seems we have tickets for what I was seeing here as issues.  Thanks!
Level XIII
Thanks for fixing issue #8 in Jmp v17.1.
Will #4, #6, #7 be fixed in v18?
Level XIII
9) open HTML file
Level XIII
10) open HDF5 file
adding Colors and Markers will be captured in JMP 17.2 maintenance release later this year.
it is known that these do not work yet.  A defect has been filed and reported
There is a Defect already opened and filed for this to be fixed.
Level XIII
ok, gerat.
"This" is #10?
there is a ticket for this ..and it is a known issue.
