Level XI
Actions missed by Advanced Log/Workflow Builder
container to collect actions which are not recorded yet.
NB:
"Workflow Builder + Add-Ins"  is already discussed in this post:
and this wish list entry:
Workflow Builder + AddIns
[More Topic Containers like this]
NB: If an action gets recorded by new version of Jmp, I  try to update the posts.
@ Jmp support, development: If I missed to do so, feel free to change the respective post (I guess you can do so)
   fixed:
1delete cell valuesLink-
2fill to end of table / fill to rowLinkJMP 17.2
2breplace missing with previous values -
3enable scroll lockLink-
4run table scriptLink-
5
12
manual row and column selection
row selection via "select rows"
Link
Link
6summary: drag n dropLink -
7row colors & markersLinkJMP 17.2
8Tables/summary: LDFLinkJMP 17.1
9open html fileLink-
10open H5 fileLink-
11copy frame contentLink-
13clear exclude / hideLink-
14Virtual Links: settingsLink-
16optimize: row deletion after selection via header graphLinkJMP 17.2
17copy to journalLink-
17a
17? - again - sorry
outline close orientation
Link-
17bdisplay box orientation -
18actions from tables red triangle menuLink-
19width=0Link-
34 REPLIES 34
Level XI
Re: Actions missed by Advanded Log/Worflow Builder
There are some actions (changes to Reports) which are not recorded directly, but indirectly because the full code of the Report will be saved once the report is closed.
That's fine
Level XI
1)  select and delete entries from a table
(deleting a full row is captured, deleting some entries: not)
Level XI
2) Fill to end of table Fill to row ...  *)
2b) replace missing with previous value from the right click/fill menu
*) fixed in v17.2
Level XI
3) enable scroll lock for a column
Level XI
4) run a table script
Level XI
5) row and column selections:
some commands work, like Select matching Cells , others don't like Select all rows
Level XI
6) click-and-drag operation from a summary table - illustrated e.g. in this post:
Place summary data in main table  by @Phil_Kay
Level XI
7) Adding Row Colors or Markers
(excluding rows, or adding labels is recorded)
-> fixed in v17.2
Level XI
Local Data Filter on the Tables/Summary platform
(new feature in Jmp 17)
-> fixed with v17.1
now the Data filter shows up in the log:
