Level XIII
Actions missed by Advanced Log/Workflow Builder
container to collect actions which are not recorded yet.
NB:
"Workflow Builder + Add-Ins"  is already discussed in this post:
and this wish list entry:
Workflow Builder + AddIns
[More Topic Containers like this]
NB: If an action gets recorded by new version of Jmp, I  try to update the posts.
@ Jmp support, development: If I missed to do so, feel free to change the respective post (I guess you can do so)
      fixed: last checked
1 delete cell values Link - 19.0.3
2 fill to end of table / fill to row Link 17.2
2b replace missing with previous values new bug 19.0.?
3 enable scroll lock Link - 19.0.3
4 run table script Link - 19.0.4
5
12
manual row and column selection
row selection via "select rows"
Link
Link
19.0.3
6 summary: drag n drop Link  - 19.0.3
7 row colors & markers Link 17.2
8 Tables/summary: LDF Link 17.1
9 open html file Link - 19.0.3
10 open H5 file Link -
11 copy frame content Link - 19.0.3
13 clear exclude / hide Link - 19.0.3
14 Virtual Links: settings Link - 19.0.3
16 optimize: row deletion after selection via header graph Link 17.2
17 copy to journal Link - 19.0.3
17a
17? - again - sorry
outline close orientation
Link 18.?
17b display box orientation   - 19.0.3
18 actions from tables red triangle menu Link - 19.0.3
19 width=0 Link -
20 initial column values Link
21 save project Link
22 operations on table scripts Link
38 REPLIES 38
Level XIII
Re: Actions missed by Advanded Log/Worflow Builder
There are some actions (changes to Reports) which are not recorded directly, but indirectly because the full code of the Report will be saved once the report is closed.
That's fine :)
Level XIII
1)  select and delete entries from a table
(deleting a full row is captured, deleting some entries: not)
(view in My Videos)
Level XIII
2) Fill to end of table Fill to row ...  *)
2b) replace missing with previous value from the right click/fill menu
*) fixed in v17.2
Level XIII
3) enable scroll lock for a column
Level XIII
4) run a table script
sure, in some cases, the result of a table script is a report.
And after closing the report, it will be recorded by Workflow Builder.
IN SOME CASES
- in many other cases, a table script does much (!) more ... and will be missing in the Workflow.
It's much easier to remove a redundant step than to manually add a missing step.
Level XIII
5) row and column selections:
some commands work, like Select matching Cells , others don't like Select all rows
Level XIII
6) click-and-drag operation from a summary table - illustrated e.g. in this post:
Place summary data in main table  by @Phil_Kay
Level XIII
7) Adding Row Colors or Markers
(excluding rows, or adding labels is recorded)
(view in My Videos)
-> fixed in v17.2
Level XIII
8)Local Data Filter on the Tables/Summary platform
(new feature in Jmp 17)
(view in My Videos)
-> fixed with v17.1 :)
now the Data filter shows up in the log:
