Level XII
Actions missed by Advanced Log/Workflow Builder
container to collect actions which are not recorded yet.
NB:
"Workflow Builder + Add-Ins"  is already discussed in this post:
and this wish list entry:
Workflow Builder + AddIns
[More Topic Containers like this]
NB: If an action gets recorded by new version of Jmp, I  try to update the posts.
@ Jmp support, development: If I missed to do so, feel free to change the respective post (I guess you can do so)
   fixed:
1delete cell valuesLink-
2fill to end of table / fill to rowLinkJMP 17.2
2breplace missing with previous values -
3enable scroll lockLink-
4run table scriptLink-
5
12
manual row and column selection
row selection via "select rows"
Link
Link
6summary: drag n dropLink -
7row colors & markersLinkJMP 17.2
8Tables/summary: LDFLinkJMP 17.1
9open html fileLink-
10open H5 fileLink-
11copy frame contentLink-
13clear exclude / hideLink-
14Virtual Links: settingsLink-
16optimize: row deletion after selection via header graphLinkJMP 17.2
17copy to journalLink-
17a
17? - again - sorry
outline close orientation
Link-
17bdisplay box orientation -
18actions from tables red triangle menuLink-
19width=0Link-
35 REPLIES 35
Re: Actions missed by Advanded Log/Worflow Builder
Sorry this didn't reply to each comment as i thought it would.  The right click Fill to and all that menu -- that is reported and a defect is out there to fix the recording.
It is correct that you can delete rows and that is recorded now -- but deleting some content in the table or columns is not recorded currently.   The color and marker issue is fixed - in 17.2 and beyond.
Running a script from the table does not record -- but if you generate a platform, then either use the red triangle menu to save that script to the workflow -- or close that platform -- that is recorded.
Just to be clear, v17.2 is not available yet - it will be the next maintenance release, available later this year.  Sorry for any confusion there.  Mostly wanted you to know we were aware of the issue and had fixed it at some point, moving forward.  Thank you for trying these things and reporting them.
Level XII
OK, curious to see what will be new ...
Level XII
11) copy and paste Frame content in Graph Builder (to overlay different plots)
Level XII
12) Select Rows from the the rows "menu" on the bottom left:
(Select Excluded from the Rows/Row Selection menu)
Level XII
13) Excluded/Clear and Hidden/Clear (in the rows menu on the bottom left)
NB: Selected/Clear is recorded
Level XII
Level XII
15) Dashboards to Workflow Builder
no issue, works like expected
Level XII
16) The example with row deletion is amazing:
Jmp understands that I want want to delete the inverse of the initial row selection.
like AI Copilot
But one has to do it like in the video:
- select a row
- select matching cells
- invert the selection
- delete rows
Then the recorded script will also work with a future table.
If the user is lazy and uses a header graph to select rows, the script is much less useful:
:column << Select Rows([matrix of rows]) << delete rows();
Fixed in Jmp 17.2
For the column deletion, Jmp deletes the last selected columns. Not wrong - but not as clever as in the first example with the rows.
cols=associative array(current data table() << get column names());
cols << remove( associative array({sex}));
For Each({col}, cols,current data table() << delete columns(col));
btw: Is there a function Delete Columns which accepts a list of columns?
Level XII
17) copy results to a Journal (Ctrl L)
 Workflow Builder or the "baby steps" into Scripting
@brady_brady :
there is no sense having this thing if someone can point and click their way to something that isn't picked up
