Level XIII
Actions missed by Advanced Log/Workflow Builder
container to collect actions which are not recorded yet.
NB:
"Workflow Builder + Add-Ins"  is already discussed in this post:
and this wish list entry:
Workflow Builder + AddIns
[More Topic Containers like this]
NB: If an action gets recorded by new version of Jmp, I  try to update the posts.
@ Jmp support, development: If I missed to do so, feel free to change the respective post (I guess you can do so)
      fixed: last checked
1 delete cell values Link - 19.0.3
2 fill to end of table / fill to row Link 17.2
2b replace missing with previous values new bug 19.0.?
3 enable scroll lock Link - 19.0.3
4 run table script Link - 19.0.4
5
12
manual row and column selection
row selection via "select rows"
Link
Link
19.0.3
6 summary: drag n drop Link  - 19.0.3
7 row colors & markers Link 17.2
8 Tables/summary: LDF Link 17.1
9 open html file Link - 19.0.3
10 open H5 file Link -
11 copy frame content Link - 19.0.3
13 clear exclude / hide Link - 19.0.3
14 Virtual Links: settings Link - 19.0.3
16 optimize: row deletion after selection via header graph Link 17.2
17 copy to journal Link - 19.0.3
17a
17? - again - sorry
outline close orientation
Link 18.?
17b display box orientation   - 19.0.3
18 actions from tables red triangle menu Link - 19.0.3
19 width=0 Link -
20 initial column values Link
21 save project Link
37 REPLIES 37
Level XIII
Re: Actions missed by Advanded Log/Worflow Builder
With Jmp18, execution of a script is now recorded in Workflow Builder:
(view in My Videos)
Level XIII
Level XIII
18)
most of the actions in the table context menu are not recorded:
Level XIII
shampton82
@hogi I can confirm 2b is not fixed in 18.0.   So sad.
Steve
Level XIII
20)
Column property - initial values.
E.g. to add the current time stamp to newly added rows
https://community.jmp.com/t5/Discussions/Initialize-data-very-useful-but-fragile/m-p/780753
Level XIII
With JMp 19.x
issue #2b got fixed:
// Replace Missing with Previous Value
For Each( {irow}, Index( 1, N Row( Data Table( "Big Class Families" ) ) ),
	{prev = Empty(), dt = Data Table( "Big Class Families" )},
	If( Is Missing( dt:height[irow] ),
		If( !Is Empty( prev ),
			dt:height[irow] = prev
		prev = dt:height[irow]
Unfortunately, the code is generated without Begin/End Data Update()
i'd guess: very slow for large data tables.
for comparison: Recode
-> here Begin/End Data Update is added by default.
// Recode column: height
Local( {dt},
	dt = Data Table( "Big Class Families" );
	dt << Begin Data Update;
	For Each Row(
		dt,
		dt:height[] = Map Value( dt:height, {62, 66}, Unmatched( dt:height ) )
	dt << Run Formulas;
	dt << End Data Update;
Level XIII
