%3CLINGO-SUB%20id%3D%22lingo-sub-680137%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EUnterst%C3%BCtzt%20Skript-Drag-and-Drop%20zwischen%20Tabellen%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-680137%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3EWas%20hat%20diese%20Wunschlistenanfrage%20inspiriert%3F%3C%2FSTRONG%3EIch%20habe%20oft%20neue%20Datentabellen%20vor%20mir%2C%20die%20fast%20identisch%20mit%20den%20alten%20sind.Ich%20muss%20die%20Plotskripte%20aus%20den%20alten%20Tabellen%20in%20die%20neuen%20ziehen.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EWelche%20Verbesserung%20w%C3%BCrden%20Sie%20sich%20w%C3%BCnschen%3F%3C%2FSTRONG%3EWenn%20ich%20ein%20Skript%20aus%20dem%20oberen%20linken%20Bereich%20eines%20Datentabellenfensters%20in%20ein%20anderes%20Fenster%20ziehe%2C%20sieht%20es%20so%20aus%2C%20als%20w%C3%BCrde%20es%20es%20akzeptieren%2C%20aber%20dann%20passiert%20nichts.Ich%20m%C3%B6chte%20in%20der%20Lage%20sein%2C%20eine%20Reihe%20von%20Skripten%20per%20Drag-and-Drop%20von%20einer%20Datentabelle%20in%20eine%20andere%20zu%20kopieren.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EWarum%20ist%20diese%20Idee%20wichtig%3F%3C%2FSTRONG%3EDas%20Ziehen%20und%20Ablegen%20des%20Skripts%20ist%20eine%20intuitive%20Aktion%2C%20die%20zu%20funktionieren%20scheint%2C%20und%20es%20ist%20frustrierend%2C%20dass%20dies%20nicht%20der%20Fall%20ist.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E(JMP%20v17%2C%20Windows%20und%20Mac)%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-680137%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EDatenzugriff%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EDatenmischung%20und%20-bereinigung%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-680260%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EBetreff%3A%20Unterst%C3%BCtzt%20Skript-Drag-and-Drop%20zwischen%20Tabellen%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-680260%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EDas%20ist%20richtig%20%E2%80%93%20es%20macht%20fast%20das%2C%20was%20der%20Benutzer%20erwartet%2C%20und%20dann%20wird%20kein%20Skript%20in%20der%20Liste%20angezeigt%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EProblemumgehung%3A%20Verwenden%20Sie%20Kopieren%20und%20Einf%C3%BCgen%20aus%20dem%20Kontextmen%C3%BC%20mit%20der%20rechten%20Maustaste.%20Es%20funktioniert%20auch%2C%20wenn%20mehrere%20Skripte%20ausgew%C3%A4hlt%20sind%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EOsterei%3C%2FSTRONG%3E%20%3A%20Kopieren%20Sie%20den%20Code%20eines%20Skripts%20(d.%20h.%20nicht%20den%3CEM%3E%20Skript%3C%2FEM%3E%20)%20und%20klicken%20Sie%20im%20Rechtsklick-Men%C3%BC%20auf%20%E2%80%9EEinf%C3%BCgen%E2%80%9C.%3C%2FP%3E%3CP%3EDadurch%20wird%20das%20Skript%20f%C3%BCr%20die%20Zieltabelle%20ausgef%C3%BChrt.%3C%2FP%3E%3CP%3EAuch%20cool%20f%C3%BCr%20Report%2FSave%20Script%20to%20Clipboard%20-%26gt%3B%20f%C3%BChren%20Sie%20es%20f%C3%BCr%20eine%20andere%20Tabelle%20aus%3C%2FP%3E%3C%2FLINGO-BODY%3E
Support script drag-and-drop between tables
What inspired this wish list request?  I often find myself with new data tables that are almost identical to old ones.  I need to pull the plotting scripts from the old tables into the new ones.
What is the improvement you would like to see?  When I drag a script from the top-left pane of a data table window to another window, it looks like it's accepting it, but then nothing happens.  I would like to be able to copy a bunch of scripts from one data table into another via drag-and-drop.
Why is this idea important?   The script drag-and-drop is an intuitive action that seems to work, and it's frustrating that it doesn't.
(JMP v17, Windows and Mac)
1 Comment
hogi
Level XII
that' right - it's almost doing what the user expects and then: no script shows up in the list
workaround: use copy & paste from the right click context menu. It also works if more scripts are selected
easter egg: copy the code of a script (i.e.: not the script) and click on paste in the right click menu.
This runs the script for the target table.
Also cool for Report/Save Script to Clipboard -> run it for another table
