%3CLINGO-SUB%20id%3D%22lingo-sub-680137%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EAdmite%20arrastrar%20y%20soltar%20scripts%20entre%20tablas%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-680137%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3E%C2%BFQu%C3%A9%20inspir%C3%B3%20esta%20solicitud%20de%20lista%20de%20deseos%3F%3C%2FSTRONG%3EA%20menudo%20me%20encuentro%20con%20tablas%20de%20datos%20nuevas%20que%20son%20casi%20id%C3%A9nticas%20a%20las%20antiguas.Necesito%20trasladar%20los%20guiones%20de%20trazado%20de%20las%20tablas%20antiguas%20a%20las%20nuevas.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%C2%BFCu%C3%A1l%20es%20la%20mejora%20que%20le%20gustar%C3%ADa%20ver%3F%3C%2FSTRONG%3ECuando%20arrastro%20un%20script%20desde%20el%20panel%20superior%20izquierdo%20de%20una%20ventana%20de%20tabla%20de%20datos%20a%20otra%20ventana%2C%20parece%20que%20lo%20acepta%2C%20pero%20luego%20no%20sucede%20nada.Me%20gustar%C3%ADa%20poder%20copiar%20un%20mont%C3%B3n%20de%20scripts%20de%20una%20tabla%20de%20datos%20a%20otra%20mediante%20arrastrar%20y%20soltar.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%C2%BFPor%20qu%C3%A9%20es%20importante%20esta%20idea%3F%3C%2FSTRONG%3EEl%20script%20de%20arrastrar%20y%20soltar%20es%20una%20acci%C3%B3n%20intuitiva%20que%20parece%20funcionar%2C%20y%20es%20frustrante%20que%20no%20lo%20haga.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E(JMP%20v17%2C%20Windows%20y%20Mac)%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-680137%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EAcceso%20a%20los%20datos%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ECombinaci%C3%B3n%20y%20limpieza%20de%20datos%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-680260%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Soporte%20para%20arrastrar%20y%20soltar%20scripts%20entre%20tablas%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-680260%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EAs%C3%AD%20es%3A%20casi%20hace%20lo%20que%20el%20usuario%20espera%20y%20luego%3A%20no%20aparece%20ning%C3%BAn%20script%20en%20la%20lista.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3ESoluci%C3%B3n%20alternativa%3A%20use%20copiar%20y%20pegar%20desde%20el%20men%C3%BA%20contextual%20del%20bot%C3%B3n%20derecho.%20Tambi%C3%A9n%20funciona%20si%20se%20seleccionan%20m%C3%A1s%20scripts.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3Eel%20huevo%20de%20Pascua%3C%2FSTRONG%3E%20%3A%20copia%20el%20c%C3%B3digo%20de%20un%20script%20(es%20decir%2C%20no%20el%3CEM%3E%20guion%3C%2FEM%3E%20)%20y%20haga%20clic%20en%20pegar%20en%20el%20men%C3%BA%20contextual.%3C%2FP%3E%3CP%3EEsto%20ejecuta%20el%20script%20para%20la%20tabla%20de%20destino.%3C%2FP%3E%3CP%3ETambi%C3%A9n%20es%20interesante%20para%20Informar%2FGuardar%20script%20en%20el%20Portapapeles%20-%26gt%3B%20ejecutarlo%20para%20otra%20tabla%3C%2FP%3E%3C%2FLINGO-BODY%3E
Support script drag-and-drop between tables
What inspired this wish list request?  I often find myself with new data tables that are almost identical to old ones.  I need to pull the plotting scripts from the old tables into the new ones.
What is the improvement you would like to see?  When I drag a script from the top-left pane of a data table window to another window, it looks like it's accepting it, but then nothing happens.  I would like to be able to copy a bunch of scripts from one data table into another via drag-and-drop.
Why is this idea important?   The script drag-and-drop is an intuitive action that seems to work, and it's frustrating that it doesn't.
(JMP v17, Windows and Mac)
1 Comment
hogi
Level XII
that' right - it's almost doing what the user expects and then: no script shows up in the list
workaround: use copy & paste from the right click context menu. It also works if more scripts are selected
easter egg: copy the code of a script (i.e.: not the script) and click on paste in the right click menu.
This runs the script for the target table.
Also cool for Report/Save Script to Clipboard -> run it for another table
