%3CLINGO-SUB%20id%3D%22lingo-sub-680137%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EPrise%20en%20charge%20du%20glisser-d%C3%A9poser%20du%20script%20entre%20les%20tables%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-680137%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3EQu'est-ce%20qui%20a%20inspir%C3%A9%20cette%20demande%20de%20liste%20de%20souhaits%26nbsp%3B%3F%3C%2FSTRONG%3EJe%20me%20retrouve%20souvent%20avec%20de%20nouveaux%20tableaux%20de%20donn%C3%A9es%20presque%20identiques%20aux%20anciens.Je%20dois%20extraire%20les%20scripts%20de%20tra%C3%A7age%20des%20anciennes%20tables%20vers%20les%20nouvelles.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EQuelle%20est%20l%E2%80%99am%C3%A9lioration%20que%20vous%20souhaiteriez%20voir%20%3F%3C%2FSTRONG%3ELorsque%20je%20fais%20glisser%20un%20script%20du%20volet%20sup%C3%A9rieur%20gauche%20d'une%20fen%C3%AAtre%20de%20table%20de%20donn%C3%A9es%20vers%20une%20autre%20fen%C3%AAtre%2C%20il%20semble%20qu'il%20l'accepte%2C%20mais%20rien%20ne%20se%20passe.J'aimerais%20pouvoir%20copier%20un%20tas%20de%20scripts%20d'une%20table%20de%20donn%C3%A9es%20dans%20une%20autre%20par%20glisser-d%C3%A9poser.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EPourquoi%20cette%20id%C3%A9e%20est-elle%20importante%20%3F%3C%2FSTRONG%3ELe%20glisser-d%C3%A9poser%20du%20script%20est%20une%20action%20intuitive%20qui%20semble%20fonctionner%2C%20mais%20il%20est%20frustrant%20que%20ce%20ne%20soit%20pas%20le%20cas.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E(JMP%20v17%2C%20Windows%20et%20Mac)%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-680137%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EAcc%C3%A8s%20aux%20donn%C3%A9es%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EM%C3%A9lange%20et%20nettoyage%20des%20donn%C3%A9es%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-680260%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%20%3A%20Prise%20en%20charge%20du%20glisser-d%C3%A9poser%20du%20script%20entre%20les%20tables%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-680260%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3Ec'est%20vrai%20-%20il%20fait%20presque%20ce%20que%20l'utilisateur%20attend%20et%20ensuite%26nbsp%3B%3A%20aucun%20script%20n'appara%C3%AEt%20dans%20la%20liste%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3Esolution%20de%20contournement%26nbsp%3B%3A%20utilisez%20le%20copier-coller%20%C3%A0%20partir%20du%20menu%20contextuel%20du%20clic%20droit.%20Cela%20fonctionne%20%C3%A9galement%20si%20plus%20de%20scripts%20sont%20s%C3%A9lectionn%C3%A9s%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%C5%93uf%20de%20P%C3%A2ques%3C%2FSTRONG%3E%20%3A%20copie%20le%20code%20d'un%20script%20(ie%20%3A%20pas%20le%3CEM%3E%20sc%C3%A9nario%3C%2FEM%3E%20)%20et%20cliquez%20sur%20coller%20dans%20le%20menu%20contextuel.%3C%2FP%3E%3CP%3ECela%20ex%C3%A9cute%20le%20script%20pour%20la%20table%20cible.%3C%2FP%3E%3CP%3EAussi%20cool%20pour%20Report%2FSave%20Script%20to%20Clipboard%20-%26gt%3B%20ex%C3%A9cutez-le%20pour%20une%20autre%20table%3C%2FP%3E%3C%2FLINGO-BODY%3E
Support script drag-and-drop between tables
What inspired this wish list request?  I often find myself with new data tables that are almost identical to old ones.  I need to pull the plotting scripts from the old tables into the new ones.
What is the improvement you would like to see?  When I drag a script from the top-left pane of a data table window to another window, it looks like it's accepting it, but then nothing happens.  I would like to be able to copy a bunch of scripts from one data table into another via drag-and-drop.
Why is this idea important?   The script drag-and-drop is an intuitive action that seems to work, and it's frustrating that it doesn't.
(JMP v17, Windows and Mac)
1 Comment
hogi
Level XII
that' right - it's almost doing what the user expects and then: no script shows up in the list
workaround: use copy & paste from the right click context menu. It also works if more scripts are selected
easter egg: copy the code of a script (i.e.: not the script) and click on paste in the right click menu.
This runs the script for the target table.
Also cool for Report/Save Script to Clipboard -> run it for another table
