What inspired this wish list request? I often find myself with new data tables that are almost identical to old ones. I need to pull the plotting scripts from the old tables into the new ones.
What is the improvement you would like to see? When I drag a script from the top-left pane of a data table window to another window, it looks like it's accepting it, but then nothing happens. I would like to be able to copy a bunch of scripts from one data table into another via drag-and-drop.
Why is this idea important? The script drag-and-drop is an intuitive action that seems to work, and it's frustrating that it doesn't.
(JMP v17, Windows and Mac)
