%3CLINGO-SUB%20id%3D%22lingo-sub-680137%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ESupporta%20il%20trascinamento%20della%20selezione%20degli%20script%20tra%20le%20tabelle%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-680137%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3ECosa%20ha%20ispirato%20questa%20richiesta%20di%20lista%20dei%20desideri%3F%3C%2FSTRONG%3ESpesso%20mi%20ritrovo%20con%20nuove%20tabelle%20dati%20quasi%20identiche%20a%20quelle%20vecchie.Devo%20inserire%20gli%20script%20di%20stampa%20dalle%20vecchie%20tabelle%20in%20quelle%20nuove.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EQual%20%C3%A8%20il%20miglioramento%20che%20vorresti%20vedere%3F%3C%2FSTRONG%3EQuando%20trascino%20uno%20script%20dal%20riquadro%20in%20alto%20a%20sinistra%20di%20una%20finestra%20di%20tabella%20dati%20a%20un'altra%20finestra%2C%20sembra%20che%20lo%20accetti%2C%20ma%20poi%20non%20succede%20nulla.Mi%20piacerebbe%20poter%20copiare%20un%20gruppo%20di%20script%20da%20una%20tabella%20dati%20a%20un'altra%20tramite%20drag-and-drop.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EPerch%C3%A9%20questa%20idea%20%C3%A8%20importante%3F%3C%2FSTRONG%3EIl%20trascinamento%20della%20selezione%20dello%20script%20%C3%A8%20un'azione%20intuitiva%20che%20sembra%20funzionare%2C%20ma%20%C3%A8%20frustrante%20che%20non%20funzioni.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E(JMP%20v17%2C%20Windows%20e%20Mac)%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-680137%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EAccesso%20ai%20dati%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ECombinazione%20e%20pulizia%20dei%20dati%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-680260%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERi%3A%20Supporto%20del%20trascinamento%20della%20selezione%20degli%20script%20tra%20le%20tabelle%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-680260%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3Eesatto%2C%20fa%20quasi%20quello%20che%20l'utente%20si%20aspetta%20e%20poi%3A%20nessuno%20script%20appare%20nell'elenco%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3Esoluzione%20alternativa%3A%20utilizzare%20copia%20e%20incolla%20dal%20menu%20contestuale%20del%20tasto%20destro.%20Funziona%20anche%20se%20vengono%20selezionati%20pi%C3%B9%20script%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3Euovo%20di%20Pasqua%3C%2FSTRONG%3E%20%3A%20copia%20il%20codice%20di%20uno%20script%20(es%3A%20non%20il%3CEM%3E%20sceneggiatura%3C%2FEM%3E%20)%20e%20fare%20clic%20su%20Incolla%20nel%20menu%20contestuale.%3C%2FP%3E%3CP%3EQuesto%20esegue%20lo%20script%20per%20la%20tabella%20di%20destinazione.%3C%2FP%3E%3CP%3EOttimo%20anche%20per%20Segnala%2FSalva%20script%20negli%20Appunti%20-%26gt%3B%20eseguilo%20per%20un'altra%20tabella%3C%2FP%3E%3C%2FLINGO-BODY%3E
Support script drag-and-drop between tables
What inspired this wish list request?  I often find myself with new data tables that are almost identical to old ones.  I need to pull the plotting scripts from the old tables into the new ones.
What is the improvement you would like to see?  When I drag a script from the top-left pane of a data table window to another window, it looks like it's accepting it, but then nothing happens.  I would like to be able to copy a bunch of scripts from one data table into another via drag-and-drop.
Why is this idea important?   The script drag-and-drop is an intuitive action that seems to work, and it's frustrating that it doesn't.
(JMP v17, Windows and Mac)
1 Comment
hogi
Level XI
that' right - it's almost doing what the user expects and then: no script shows up in the list
workaround: use copy & paste from the right click context menu. It also works if more scripts are selected
easter egg: copy the code of a script (i.e.: not the script) and click on paste in the right click menu.
This runs the script for the target table.
Also cool for Report/Save Script to Clipboard -> run it for another table
